Wheels Tires Wheels, Tires
FS: Circuit Sports Spacers 25mm and 30mm pairs
Old Jun 28, 2014 | 02:19 PM
lixam's Avatar
lixam
Default Circuit Sports Spacers 25mm and 30mm pairs
2 sets of Circuit Sports spacers, 1 pair of 25mm and 1 pair of 30mm- 5x114.3
Were on my G35, just no longer need them, installing the 25mm up front and the 30mm in back on the 19" G sport wheels makes everything nice and flush on coupes and will fit most Nissan, Toyotas and anything with a 5x114.3 bolt pattern. Sits perfect on G35s/350z/370z/G37s and etc.
Both sets come with all bolts and standard built in studs, and I'll throw in all 4 hub rings as well
Price lowered:
Per set:
$90.00-buyer pays shipping
$85.00-local (Alexandria, VA)
Both sets:
$175.00 buyer pays shipping
$165.00 local (Alexandria, VA)
MSRP $125.00-145.00 per set with hub rings.\
Description below:
Circuit Sports Altrac bolt on type wheel spacers is made to fit for your Nissan vehicle. This wheel spacer is made for the vehicles that are equipped with the 5x114.3 wheel bolt pattern. The available Altrac spacers range from 15mm to 30mm in thickness providing a wide range of fitment for your vehicle. Each spacer is sold in a pair of 2.
Specifications:
Spacers machined from billet T6 aluminum
Heat treated carbon steel wheel studs for strength
Black coating on wheel studs to ensure durability and avoid premature corrosion
Anodized silver coating on spacer aluminum body for durability and long lasting finish
Uni-lateral wheel stud length ensure all wheel studs are the same length across 15 to 30mm spacer thickness (some others uses longer wheel studs to make up the thicker wheel spacers which weakens the structure of the spacer)
Ring lock type spacer hub rings (not floating hub rings like others) provides additional measures to safety and structure of the wheel spacers
7147211162
vincent.honorato@yahoo.com
for fastest response.
Old Jul 1, 2014 | 04:11 PM
lixam's Avatar
lixam
Price lowered:
Per set:
Both sets:
bump!
HoBrahYouStink
Jun 24, 2016 10:58 PM
