Sponsored by:
Sponsored by:
Need help with front fender clearance
Old 12-07-2016, 02:18 PM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
meh, let him screw up his fenders. we tried to help him
Old 12-08-2016, 05:26 AM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
But I already got the wrong sized tire...
There is a tire and wheel calculator located at the top of the page. All it takes is a few seconds to figure it out.
Old 01-17-2017, 06:20 AM
ivanorcan
ivanorcan's Avatar
Hi Guys,
My mechanic had the tool to roll the fenders, we did it and the issue was solved. We also measured the wheels and found out they sent the wrong offset for the front, as it is +12, im saving some money to order the front wheels again with the correct offset.
Thanks for the help!
Old 01-23-2017, 06:51 AM
Phenom
Toasty
Phenom's Avatar
Received 1,382 Likes on 990 Posts
Before seeing your last post, I was going to say those definitely aren't +22 wheels and actually look more like +12 to +15. I have +22 wheels on the front with 255 tires and I have significantly more clearance than you do and I'm also a bit lower.
Old 01-25-2017, 02:04 AM
rearranged
rearranged's Avatar
Originally Posted by ZmanIsCool
You have 245/45/18 front and 275/40/18 on the back, right?
Regarding the front tires, the 245 is the tire's width where the treads meet the road. The 45 is the height of the sidewalls. The 18, of course, is the size of your rims.
First of all, your Zcar came with 16" rims, so you're adding an extra 2" to the height of the tire in the wheel well.
Secondly, a typical Zcar tire setup is to have the wider and higher tires in the back (as you do) and the narrower, lower profile tires in the front.
Therefore, your front tires should be, using your example, 245/40/18 or 245/30/18, both lower profile (height) tires than what you have now.
I've never customized my wheels and fenders on my 3 Zcars, but I know getting the correct tires should be your first step. Then you might be able to have the fenders rolled if clearance is still a problem.
Z
This is full of bad advice. Take this with a grain of salt.
pyshin (01-25-2017)
Old 01-25-2017, 02:51 AM
travlee
Master
travlee's Avatar
yep... but then again zmanistardo only has 7 posts, i wouldnt trust him
Old 01-25-2017, 04:59 AM
dboyzalter
dboyzalter's Avatar
Z
Did your Z car come with 5 spares?
Old 01-25-2017, 05:03 AM
dboyzalter
dboyzalter's Avatar
Originally Posted by ivanorcan
Hi Guys,
You should keep the wheels and just get new front tires... The 18x9.5 +12 is fine... The 245/45 front tire is the problem.
You need a 245/40 or 255/40...
