steering rack guide adjustment
on
I am trying to make an adjustment to the rack guide screw on my 2006 350Z to tighten up my steering and I have read some information on this but everywhere I look it says there is a larger 40mm locking nut and a smaller 14mm screw in the middle. I looked on my car and found only a nut (looks to be 40mm) with no smaller guide screw in the middle (see pics). They tell you to loosen the 40mm locking nut, then tighten, loosen, re-tighten the 14mm screw and then loosen about 20-30 degrees. Shouldn't there be a smaller 14mm guide screw inside the 40mm locking nut? I don't see one on my rack. If I'm looking at the rack from underneath the car I should see it facing the rear of the car, correct? So the question is what am I supposed to do to make the adjustment if I do not see a guide screw? Any help would be appreciated.
