Project: Nismo roadster
Old 06-26-2015, 06:09 AM
  #461
Heel Til I Die
Heel Til I Die's Avatar
Received 1,063 Likes on 751 Posts
Looking good, man!
Old 06-26-2015, 05:04 PM
  #462
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
Awwreeet, DeusDood!! That looks sweet. Now, let me tell you about a couple other Nismo things you missed that you need to do to make it a 100% accurate. Let's start with.....
Hahahahaha. J/K.
Seriously, at the beginning of this thread, I had doubts. But man, the dedication to authenticity and "getting it right".... paid off!
Mic
Old 06-26-2015, 10:27 PM
  #463
DeusExMaxima
DeusExMaxima's Avatar
Thank you Mic and heel.....jeez mic, you had me going. I thought "what else could I be missing???"
Today, I took a 160 mile trip up to Big Bear Lake, deep in the mountains. The car handles superbly....the wider wheels and tires helped. The bigger wheels slowed the acceleration noticably...sorry "real" Nismo owners...the Track wheels are better performing. The Conti tires have a great ride, which made the car feel like its gliding.
Here is a better pic:
On the way home, my front undertray detached from the rear and dragged on the ground. I'll likely replace it.
Old 06-27-2015, 04:01 AM
  #464
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
I've been to bear lake area, it was pretty up there
Old 07-02-2015, 07:31 AM
  #465
sofakiing
sofakiing's Avatar
Originally Posted by DeusExMaxima
the problem is that the larger wing likely would not look good on a convertible which is why i went with the v1 wing. if someone wants to photochop a v3 wing on a vert id love to see it!!
My Nismo side skirt extensions came in today. Looks like I have a weekend painting project!!
where did you get these?
Old 07-02-2015, 09:49 AM
  #466
kno
kno's Avatar
Sofaking is going the v3 route?
Old 07-02-2015, 09:57 AM
  #467
sofakiing
sofakiing's Avatar
exploring options at the moment.
Old 07-02-2015, 04:41 PM
  #468
350zchad
350zchad's Avatar
BRAVO!! She is looking great!
Zspeed undertray FTW!
Old 07-05-2015, 05:33 PM
  #469
ChrisFL350Z
ChrisFL350Z's Avatar
I've been looking through your post on the progression of this... car looks amazing! What 2 sets of rims did/do you have on it? I'm looking for a set to put on mine and I really like the second set you put on.
Old 07-06-2015, 09:33 AM
  #470
Heel Til I Die
The first wheels were the 18" V1 Track wheels and his current set up are the 18"/19" Nismo (or V3) wheels.
They're tough to find in good shape. I know Deus had a fun time tracking down a set!
Old 07-07-2015, 05:14 AM
  #471
ChrisFL350Z
Thanks! At least I have a lead now on what I might do for wheels
Old 07-13-2015, 09:21 PM
  #472
DeusExMaxima
Im back from out of town where I had barely any cell service....
Yes first set of rims were Track edition rims that I painted graphite. Great rims!! Wish they were a tad wider. Second set was V3 Nismo rims and yes, what fun finding those!!!
I need to fix the undertray. I think ill get the metal one. Can I drive the car in the meantime without the undertray?
Old 07-14-2015, 06:27 AM
  #473
MicVelo's Avatar
Chris, a slightly less expensive option (if you are pre-disposed to Nismo V3s) are the Track 2/Grand Touring wheels.
Exactly the same wheel/tire size setup as V3....
18x9 +30 245/40-18 Front
19x10 +30 265/35-19 Rear
Only diff (as shown in poor pic below) are the signature "Z-dots" versus the groove & Nismo sticker on the V3s.
Thusly...
Identical boat anchor weight F&R. (These are NOT light but stronger than most cast wheels and can take a lot of abuse.) Still somewhat difficult to find but a little less $$ when you do. I paid ~$700 with 50% Yoks for the set on my silver car. (Lightly rashed but good for rim-fixer project)
I run 275 rears but kno is running 285s on same 10" rear wheels and they fit well.
Old 07-15-2015, 07:59 AM
  #474
Heel Til I Die
You should be fine driving it without that flimsy "shield." It doesn't really provide any type of rigidity or benefit other than keeping road grime and dirt out. Of course, a good washing can always clean that up.
I've got the Zspeed undertray. It's pretty nice and has a panel to access the oil filter which eliminates the inconvenience of removing the entire thing during oil changes. I'm not sure how it will bolt up to your V3 front, but it may simply be interchangeable. I think Zspeed may also sell some extension pieces for some bumpers. It does kind of reinforce my OEM front bumper since the undertray is rigid metal.
Old 07-15-2015, 01:33 PM
  #475
Resmarted
Resmarted's Avatar
It dramatically affects airflow actually. It provide a barrier for air to go through the radiator etc. Without it air just spills down and out the car from the front end.
Old 07-17-2015, 07:36 AM
  #476
Heel Til I Die
That makes sense. I stand corrected.
Old 07-17-2015, 08:46 AM
  #477
ZSpeedPerformance
Vendor - Former Vendor
ZSpeedPerformance's Avatar
These will fix your undertray issues
http://www.zspeedperformance.com/ZSp...SP2002-Z33.htm
http://www.zspeedperformance.com/ZSp...el-ZSP2012.htm
Old 07-17-2015, 06:24 PM
  #478
350zchad
350zchad's Avatar
Default Project: Nismo roadster
Listen to ZSpeed, best option available!
Old 07-21-2015, 11:58 AM
  #479
DeusExMaxima
I have the bumper extension - it may even be a Z speed extension actually. I just need the undertray. Has anyone installed a rear undertray, particularly on a Nismo Z?
Old 07-22-2015, 10:14 AM
  #480
Heel Til I Die
I've seen a few posts with endorsements from the Nismo guys. Here's ZSpeed's vendor post with a pic of it mounted on the V3 front bumper: https://my350z.com/forum/body-exteri...h-shields.html
I have it on my '05 roadster and it is great. It mounts right up to the existing mounting holes that the OEM tray used.
Quick Reply: Project: Nismo roadster
