Parking Light Wire
Parking Light Wire
Hey all, I am trying to retrofit an illuminated ignition piece from the HR models. I have it all nice and snug, my problem is the wiring.
I want to it to turn on when I turn on my parking light/head light switch. I found the wire near at driver kick panel and tried to splice into it, but it didn't work. As I was taking it off the wire split. I was curious to see if I even had the right wire so I turned on my parking lights and headlights but they still turned on!
Since the red/blue parking light wire is now split shouldnt the parking lights be unable to turn on?
Is there another area of the parking light wire that is easier to splice into?
If you are going to get into electronics in your car you need to buy a test light. Very cheap. You should be able to tap into it in the trunk area. That wire receives power when you turn on the parking light. Very easy to check. As for the spliced wire you would soon find out what it is if something stops working. I suggest you connect it back together
One last question
Do you know if I can splice into the radio illumination wire?
backyardjoe
Wheels Tires
03-04-2016 11:16 PM
DarkCreep
02-25-2016 09:39 PM
