do you have sets for CF trunks gutted? super light
Unfortunately we do not at the moment. We also offer OEM replacement hatch struts which can be found HERE however they are significantly more expensive.
Our HP version should work for your setup, but may require a significant amount of force to close the hatch.
Originally Posted by Z04
got mine a few week ago after seeing them at Zattack here in Nashville and these things rock.
Thank you! I hope you enjoyed Zattack, we sure did!
HP version break the carbon hatch if you try close them. Im still in the look out for a set, even if they are smaller overall lenght. just probly need 10lb ones like hood struts
Our new Mild High Pressure Units (MHP) are great for cars without spoilers or the stock standard spoiler, while still being stronger than stock they are the lowest pressure we offer and closest to stock strength.
i'm trying to figure out which struts will work with my setup. i have a seibon oem hatch with lexan plexiglass with a voltex type 8 1700mm wing. should i get the HP or UHP? thanks
How are you stock struts handling that setup? Or are they completely shot? Any idea weight of that setup vs stock? I would probably lean towards the new MHP, none of our struts have been tested on CF hatches.
i don't use any struts with it at the moment. i sold the stock ones along with my stock hatch. in terms of weight i know the change from oem to cf hatch is a big difference esp with the lexan installed. as for the wing, i've carried it and i'm guessing it probably weighs about 20-30 lbs?
I would be hesitant to suggest any of our hatch struts for a CF hatch without testing, but if you were going to try a set, I would go with the MHP.
