How To - Shift knob for 5AT
Old 02-13-2007, 11:11 PM
  #101
iilljlllii
iilljlllii's Avatar
Originally Posted by keosh
If u want a lower budget on this go withe the pilot looks almost exactly the same and only cost me 20.00 bucks at pepboys
any pics?
Old 02-14-2007, 03:50 AM
  #102
sq40
sq40's Avatar
Originally Posted by driftk1d
coud you tell me how to make my boot look like that? mines alllll messed up...i want it to look clean like yous, pics would help
You basically need to Cut some material off of the Silver Trim Ring's Bottom. I have several Pix on back through this thread.
Remove the Ring AND the AC/Control/Console Peice.
Put the Boot over the shift lever, and install the ****.
Peel the sides of the boot u over the **** like you are peeling off a sock. Then grab the ring on the boot and screw it in to the ****. Once it is a t the position you like, Peel it back down and put it exactly over the console.
With everyting how you want it. (I Left just a little slack in my Boot), Re-install the AC/Control/Console Peice.
Make sure you are still where you want the boot, and gently slide the silver ring over the boot. You will have to "tamp" it with you fist in a few places, try not to tear the boot and dont use anything more than a small rubber mallet if you need to use a tool.
Old 02-19-2007, 06:30 PM
  #103
sq40
sq40's Avatar
Originally Posted by chriskabobbers
aww man what should i do if i think i lost the rubber stopper thing? and was it supposed to come with the small screws? i think i remember my momo shift **** just coming with the shift **** and instructions, nothing more. what do i do? is it possible to do it without a stopper and or screws? =/
It will keep comming off. Don't Frett though, Min didn't come with one either. Go to lowes and get a peice of hard plastic tubing that is just a bit bigger than the Inside Diameter of the ****. (You can find this in the section where they sell screws/washers) Cut a Slit in it wide enough that you can compress it to fit in the ****. Put it inside the **** and slide it over the stick and tighten your screws down. Works like a charm.
Old 02-19-2007, 07:00 PM
  #104
nismo*son
nismo*son's Avatar
how do you shift in park and rev or drive with the man **** on is there a button?
Old 02-19-2007, 08:11 PM
  #105
stereoneeds
stereoneeds's Avatar
yes the top of the shifter has a button you push down to change.
Old 02-20-2007, 04:21 AM
  #106
sq40
sq40's Avatar
you said to buy a tubing that is bigger than the inside of the ****, is that because it needs to stop the **** from going down any further? cuz i want to make it like the shorter shifting version like people were doing in previous posts, and i wanted to take that blue stick out like the others did too.
The Screws are also Available at most Hardware Stores, They are just Inset Allen Screws. I beleive they are Fine Thread, You sould be able to find some with no trouble and test fit them. Take the **** with you to the Hardware store.
Old 02-20-2007, 05:02 AM
  #107
sq40
sq40's Avatar
Not to stick out or stop it, I mean the Inside Diameter of the kob when you slide the tube in. When you cut it and insert it, It will un-compress and make a tight fit inside the ****, and give your clearance for the stift lever. The "blue thing" is inconcequential.
Old 03-04-2007, 08:31 AM
  #108
AlvinHuyN
Nismo 370Z #697
AlvinHuyN's Avatar
anyone wanan hook me up with their blue extension piece? I need it to install the 06 shift **** on my 03 =(
Old 04-02-2007, 12:52 PM
  #109
downshift z
downshift z's Avatar
looks good! very cleann
Old 04-03-2007, 03:32 AM
  #110
Mesto
Mesto's Avatar
YOU PERPETRATORS! Frontin Like you have a Manual Tranny..
Good Mod though, hate how the AT shifters look.
Old 04-23-2007, 03:52 PM
  #111
joe645733
joe645733's Avatar
poser looking haha, why would u buy an AT anywayz...
Old 04-23-2007, 07:30 PM
  #112
infamous350
infamous350's Avatar
easiest way you could do that install is to trade your car for a 6speed lol
Old 05-19-2007, 09:52 AM
  #113
RollTideZ
RollTideZ's Avatar
Just installed mine. Looks good.
Old 05-21-2007, 11:35 AM
  #114
brandonanix
brandonanix's Avatar
people are hating on this mod, but the thing is, that new BMW's and other high end cars with AT come with a leather boot. And people hating on AT, must not realize that some of the worlds most saught after cars are AT only.
Old 07-24-2007, 05:50 AM
  #115
james840a
james840a's Avatar
Wouldnt call that easy to much head aches with dealers.
Old 07-30-2007, 02:04 PM
  #116
QdotJ
QdotJ's Avatar
Time to wake this old thread up.
Wondering if I should go with burnt orange, or just grab a black leather boot for a "clean" look? I am afraid that the colors will not match just right....
(yeah, before anyone says anything, I'll be flushing the head unit this weekend when I get time...)
Old 07-30-2007, 11:42 PM
  #117
Pooplet
Pooplet's Avatar
only part i dont understand is how the boot is held up at the top portion.
Old 07-31-2007, 05:18 AM
  #118
z-u-later
z-u-later's Avatar
I have the Momo shift **** & boot. The top of the boot has a threaded area that is threaded into the bottom threaded area of the shift ****. I wouldn't worry about the A/T haters. I've been driving M/Ts longer than these haters are alive. When they start having problems with their M/Ts, that's when I get my satisfaction knowing that the A/T is bulletproof and performs just as well as M/Ts.
The look on M/T drivers when I kick their arzzes in auto-x --- PRICELESS!
Old 07-31-2007, 02:42 PM
  #119
james840a
james840a's Avatar
Go with Black with orange striching in it.
Old 07-31-2007, 04:34 PM
  #120
QdotJ
QdotJ's Avatar
Exactly... I am 6'5" wear a size 14" (or so) shoe, and do not have the room to shuffle my feet looking for the clutch. Not to mention, I didn't want a manual so I didn't buy one. Just like I didn't want a Jetta, a Hybrid, a Mustang or anything else...
I got what I wanted, and until any of these people are paying my mortgage, clothing me, insuring me or any of the above, then they can all keep their mouths shut.
Ok, I'm done with my rant....
Quick Reply: How To - Shift knob for 5AT
