**Cusco Cage install** - Not Fun
Old 08-29-2007, 04:36 PM
  #101
THE TECH
THE TECH's Avatar
Originally Posted by chriskabobbers
i researched the autopower roll bars and all I found were that the rollbar's that they had were welding required. So kirk is direct bolt in?
Not sure what you were reading, but the Autopower are all bolt-in.
Old 08-29-2007, 07:41 PM
  #102
rich harris
rich harris's Avatar
subscribing...Nice write-up.
Old 08-30-2007, 12:59 PM
  #103
Axelerate
Axelerate's Avatar
i have the auto-power, and the main hoop has to be welded in. The cross-bar and the harness bar are removable.
the Kirk bar is a complete bolt in.
Old 08-30-2007, 01:10 PM
  #104
THE TECH
THE TECH's Avatar
You can get the Autopower kits for bolt-in or weld-in.
Old 08-30-2007, 01:26 PM
  #105
Axelerate
Axelerate's Avatar
They dont have a bolt in kit available. Because of where the bar mounts, it has to be welded in. The cage option that you can add to the roll bar is bolt in, but the main hoop has to be welded in.
From IO port's web sight:
http://www.ioportracing.com/rbc/350Z/index.htm
Old 09-30-2007, 08:42 PM
  #106
asianracerchick
asianracerchick's Avatar
Originally Posted by 97supratt
I knew that would be a tricky one. So do the backing plates actually go into the wheel wells?
Originally Posted by Volk350Z
yup.. it has to
if the backing plates go in wheel wells wouldnt it be hitting the tires if your Z is really Lowered? or does it have enough clearance? just curious cause i just ordered this roll cage kit too...
Old 09-30-2007, 10:08 PM
  #107
97supratt
97supratt's Avatar
I installed the rear bars, and the plates don't hit the tires don't worry.
Old 10-01-2007, 12:30 PM
  #108
MaRbLe
MaRbLe's Avatar
Do you have a pic of where you welded the main hoop? Also about how much does that cage weigh?
Old 10-02-2007, 04:57 PM
  #109
imonlykidden
imonlykidden's Avatar
decent write up. Should aslo include for those who do not know how to take off all those plastic pieces.
Looks good, keeping it blue?
Old 10-02-2007, 05:25 PM
  #110
97supratt
97supratt's Avatar
The plastic pieces come off pretty easily, pull and hope it doesn't break.
Old 12-16-2007, 10:42 PM
  #111
Manjot
Manjot's Avatar
nice
Old 12-17-2007, 08:06 AM
  #112
97supratt
97supratt's Avatar
Old threads FTW! haha
Old 01-10-2008, 11:33 AM
  #113
bbs350z
bbs350z's Avatar
how would this work with a gt spec underbody brace?? reason i ask is because the bolts go through the floor, into the underbody, and it looks as though thats where the gt spec underbody brace sits.
it bolts up top here
and underneath here with the mounting plate
but the gtspec bolts there too i believe. could i just mount the plate and use the brace over it?
Old 01-10-2008, 12:26 PM
  #114
THE TECH
THE TECH's Avatar
It has nothing to do with the GT brace. They are not even close to each other.
Old 01-10-2008, 03:34 PM
  #115
bbs350z
bbs350z's Avatar
damn me = fail
i thought it seemed legit question. guess not. shut down by the tech
Old 01-10-2008, 03:38 PM
  #116
THE TECH
THE TECH's Avatar
damn me = fail
Not shutdown bro. Just letting you know that one will not interfere with the other.
Old 01-11-2008, 12:05 AM
  #117
bbs350z
bbs350z's Avatar
hopefully you part ways with yours soon so i can have it
Old 02-17-2008, 12:19 PM
  #118
Ruthless18x
Ruthless18x's Avatar
97supratt, or somebody else maybe knows?
This cage is kicking my ***, I cannot get the main hoop to line up correctly, it either hits the ceiling or is all crooked. Do you have to lean it a certain way to bolt it in correctly? Also how the hell do you get the rear panels off for the rear braces?
Thanks guys.
Old 03-01-2008, 04:13 PM
  #119
chriskabobbers
chriskabobbers's Avatar
Thanks guys.
i am having the same problem with the hoop not fitting last night, but i'm about to go back over to my brother's house to attempt it again, so I Pm'd Arin last night asking him about this, and he gave me this answer, hope it helps you too.
"Actually I recently removed the cage and I didn't have to take out the interior pieces which was weird. It might have softened up or something i'm not sure. The interior of the Z is sorta weird, if you look at the mounting point on the floor board there is a elevated point and there is a big drop and thats where you're supposed to mount it. It is a little frustrating but try to tilt the main hoop forward. Towards the rear view mirror, then put the bottom mounting points onto those deep areas of the floor board. once u do that you can try to tilt it back. That is the best way to do it because it gives u the most leverage.
The thing with the seat belt mechanism was a little my fault because I didn't install the rear two pieces. If you install the rear two pieces it'll push the main hoop forward and it won't press against the seat belt mechanism and ruin it. Here's a good piece of advice, put everything together before bolting it on or making holes. Make sure it's not in the way of anything. "
Old 03-01-2008, 05:17 PM
  #120
97supratt
97supratt's Avatar
I feel like I should start a 1-900 number for this. hahaha
Quick Reply: **Cusco Cage install** - Not Fun
