Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Do It Yourself Guides > Body, Interior, Exterior & Lighting (DIY)
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 04-03-2008, 07:42 PM   #1
ctwentytwo
Points: 6,915, Level: 54
Points: 6,915, Level: 54 Points: 6,915, Level: 54 Points: 6,915, Level: 54
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default DIY- Shift Knob finisher (Ballcok shank washer shaping) for Nismo GT Ti Knob.
Every once in a while I get PM'ed about my shift knob finisher. It's just the infamous Ballcock shank wahser. Unfortunately, if you use the washer out of the box with the Nismo GT Ti Knob, it's too big and looks ugly.
Here's the how to to pretty it up, and to extend the knob just a little to make it more comfortable.
Here's what you need:
  • Nismo GT Ti Knob. Obviously.
  • Ballcock Shank Washer from Lowes. All the info you need is in the pic.
  • Drill
  • Masking Tape
  • Rough and Smooth sandpaper.
  • Elmers glue (wood glue, carpenters glue, school glue)
  • Scissors
  • Drill Bit (the bigger the better)
  • Wooden Stick
  • 1" Diameter Plastic Pipe
  • Permatex Blue Thread Lock
The Work:
  • Cut the sandpaper to size and glue to the wooden stick as shown above. Wait to dry (5-10min.)
  • If you want to shorten the size of the washer, just rub the washer on the sandpaper and size to your liking. Keep the washer as flat to the surface of the sandpaper as possible. You don't want it to be lopsided. Keep turning the washer as you're sanding occasionally to keep things even.
  • If you want to taper the washer, wrap the masking tape around the drill bit so that it's fat enough to fit the washer on.
    I would clamp the sandpaper stick to a table instead of holding it with your feet like me. Put the washer on the modified drill bit making sure it's tight, and use it like a lathe. You might want to put on some eye protection. Use the drill's highest speed and CAREFULLY press the washer against the sandpaper in the angle shown above.
  • How you shape it is up to you. Just be careful. BTW, it's not as dangerous as it looks. Just don't make it too short or else it'll be loose.
Taking it a step above. Adding the extension.
  • Take the plastic pipe and shape it like this:
    Use the same drill bit with the tape on and tape until the pipe fits tight. Use the sandpaper stick or file and grind the tips down to form a notch. Make sure you don't grind too much or else it will be loose. Keep test fitting on both the knob and washer. It should fit like this:
    In the end, you control how high you want the extension to extend... but you may need some other hardware, which I'll bring up later.
  • The final product. A little shorter and less wide.
  • Compare the shaped one, to the unmolested washer.
  • If you do decide to go higher, you'll need washers to fill the void between the inner piece of the knob (shown above threaded on top of the shifter shaft) and the knob itself. How much washers you'll need depends on how high you went. Sorry, forgot the size of the washers)
    Here you can see the washer in the knob. Mine does not need washers as I decided to keep the knob in the stock position.
    You'll also need a longer top screw. You can find longer screws with the hex heads at Lowes (the shortest screw on the right is the original.) I forgot the size of the pitch, but they are in metric sizes. Just bring your original to Lowes.
    You can sand the top of the head to make it shiny instead of keeping it black. Lowe's only has black screws.
  • I also used a rubber gasket (show above to the right of the knob... deformed from the pressure) to keep the top screw tight, avoiding the metal to metal contact of the knob and the inner piece of the knob which may loosen later.
    Just make sure you use the permatex blue thread lock when putting on the inner piece (shown on top of the shifter shaft above.) BTW, this is why it's such a PITA to take your stock one off... and is why many complain that their knob is loose. You can also use it on the top screw, but I decided against it, hence the rubber gasket.
  • A shot comparing an unshaped washer to a shaped one.
__________________
100% Authentic... say no to knock-offs. http://www.flickr.com/photos/ctwentytwo/ (My Photos on Flickr)
ctwentytwo is offline   Reply With Quote
Old 04-03-2008, 07:57 PM   #2
_NIZMO_
_NIZMO_'s Avatar
Points: 5,958, Level: 50
Points: 5,958, Level: 50 Points: 5,958, Level: 50 Points: 5,958, Level: 50
Today's Activity: 0.7%
Today's Activity: 0.7% Today's Activity: 0.7% Today's Activity: 0.7%
Very nice write-up
_NIZMO_ is offline   Reply With Quote
Old 04-03-2008, 10:50 PM   #3
Z_Youlater
Z_Youlater's Avatar
Send a message via AIM to Z_Youlater
Dang...That's pretty clean dude. nice write-up.
-Tu-
Z_Youlater is offline   Reply With Quote
Old 04-03-2008, 10:55 PM   #4
350ZTheStandard
350ZTheStandard's Avatar
Points: 3,756, Level: 38
Points: 3,756, Level: 38 Points: 3,756, Level: 38 Points: 3,756, Level: 38
Today's Activity: 3.9%
Today's Activity: 3.9% Today's Activity: 3.9% Today's Activity: 3.9%
Sweet, just found me a weekend project saving me $$$$$ buying a aftermarket finisher. Thanks
__________________
chewwwy momma, hot diggety & shazam, be manly & have a good day.
350ZTheStandard is offline   Reply With Quote
Old 04-04-2008, 09:32 AM   #5
vo7848
vo7848's Avatar
Points: 24,217, Level: 94
Points: 24,217, Level: 94 Points: 24,217, Level: 94 Points: 24,217, Level: 94
Today's Activity: 21.4%
Today's Activity: 21.4% Today's Activity: 21.4% Today's Activity: 21.4%
Nice write-up. I'd love to see what the 1" diameter pipe looked like before you shaped it...
__________________
Team Nextstage
Sponsored by Meguiar's, Imported Performance
www.teamnextstage.com
Team DNF n00bslayer & eater of children............................................................ ...............
vo7848 is offline   Reply With Quote
Old 04-04-2008, 09:40 AM   #6
ctwentytwo
Quote:
I used a sprinkler pipe that's only about 4" long, but it's not thick.
I was too lazy to call the worker to cut a piece off in the plumbing section.
Just look for regular plumbing pipe that's 1" in diameter, as they are thick enough and you won't get all funky looking like this:
You just need to get the top and bottom skinner to fit into the knob and Ballcock washer. Yeah, ballcock, ballcock, ba...
Also, for those looking to make the knob sit higher... you don't need the washers. Just don't tighten the inner piece too far down on the shifter shaft... shaft... shaft Although I'd give it at least 5 full turns to grab enough threads. And again, use the Permatex Thread Lock... blue is enough, red if you're paranoid.
__________________
Old 04-04-2008, 10:21 AM   #7
vo7848
vo7848's Avatar
Quote:
That's what I was curious about, is the thickness of the pipe. It must be pretty thick to gouge out grooves that deep. I'm trying to figure out a way to incorporate your method to my current set-up. Only difference is that I have a stainless steel finisher with the ARC knob. It's a perfect mate, only it rattles a bit under load. I'd also like to be able to torque the shift knob down a bit more without the finisher moving or being forced down futher.
Here's my write-up:http://www.my350z.com/forum/showthread.php?t=318963
__________________
Team Nextstage
Old 09-22-2008, 10:18 AM   #8
JasonZ-YA
JasonZ-YA's Avatar
Points: 30,522, Level: 100
Points: 30,522, Level: 100 Points: 30,522, Level: 100 Points: 30,522, Level: 100
Today's Activity: 3.6%
Today's Activity: 3.6% Today's Activity: 3.6% Today's Activity: 3.6%
Send a message via AIM to JasonZ-YA Send a message via Yahoo to JasonZ-YA
I did this with the Home depot/Lowes finisher......CF..
http://my350z.com/forum/5880823-post77.html
__________________
04 PPW Touring - My favorite mod is my short Dodge Avenger antenna
JasonZ-YA is online now   Reply With Quote
Old 11-04-2008, 04:52 PM   #9
bigbgballz
bigbgballz's Avatar
Points: 1,352, Level: 20
Points: 1,352, Level: 20 Points: 1,352, Level: 20 Points: 1,352, Level: 20
Question finish
What is the finish on the finisher? It looks kinda glossy? It looks very nice by the way!
bigbgballz is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
07, 350z, ballcok, diy, finisher, inside, knob, knobs, nismo, piece, plastic, shank, shift, ti, washer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
