Wheel Hub Assembly (wheel bearing) replacement - FRONT - HOW TO
on
http://g35driver.com/forums/brakes-s...g-removal.html
DIY for rear wheel bearings currently in progress
on
http://www.trademotion.com/partlocat...layCatalogid=0
$134.09 and free shipping
i bought my rear wheel bearing, hub, seal, etc from them. if they don;t have it in stock, takes 2-3 days for them to order it for you.
cheapest place you will find once you factor in shipping from other online stores.
on
I am replacing my wheel hub assembly on my 2003 Nissan 350Z non-brembo. looking at the Nissan Repair Manual it seems there are alot of parts to remove. reading this thread, it seems you can get to it by
1) remove the calipers (2 bolts)
2) remove the rotors
3) remove the 4 bolts that holds the hub assembly in place.
then reverse the order. is this exactly all the steps or is there something else? any additional steps/parts no matter how small, please advise
i have never done a repair like this at all and don't want any surprises. just the manual has so many parts to remove
thanks in advance!
thanks in advance!
thanks in advance!
thanks in advance!
#40
A lot of people have stated that the wobble must be tested by holding the top and bottom of the wheel, my wheel doesnt wobble like that, but if i grab it on the sides, there is a wobble, is that just due to free play that must be there due to steering components or is the hub in need of replacing?? The other side doesnt wobble at all and i have this humming noise coming from one of the wheels so i think its the bearing... any help??
