DIY - Lower Control Arm Bushing Replacement - Translink
Old 01-05-2010, 03:22 PM
  #61
Z1 Performance
Former Sponsor
Z1 Performance's Avatar
I don't think we're understanding each other
You are assuming that the stock bushing is going bad because people are torquing the bolts down with the car in the air. Since you did not specify which bolts, I assumed (incorrectly?) that you mean the bolts for the lower control arm itself. My point is that there is no install that I am aware that would require you remove the inner bolt (control arm to chassis) at all. That is why it makes no sense. Perhaps you can elaborate as to what you mean?
I am not questioning what you know, nor what is in the FSM (I follow it to a T on my car), but I guess I am just missing what you're saying.
Or are you saying that merely by virtue of the fact that the car is suspended in the air, without disconnecting the lower control arm completely, that it's somehow putting too much load on the bushing causing it to wear?
The inner bushing is the one prone towards failing. Many people choose to also do the outer bushing (shock to control arm) at the same time since the arm is coming out anyway. However, there is no condition under which anyone has any reason to touch the inner control arm bolt unless they are removing the control arm itself. The only reason I can think of to remove the arm itself, is to replace the bushing (or the arm if its bent, etc).
Old 01-05-2010, 04:10 PM
  #62
johnlotusboy
johnlotusboy's Avatar
I remove the inner bolt to remove strut. The factory bushing doesn't pivot like a bearing, all movement is a factor of torsional deflection. Any preload will shorten life of bushing. If you push way down on the arm to get your strut out after disconnecting the ball joint, you are damaging the bushing.
Urethane bushings actually pivot, but they wear because of this difference. The urethane "bearing" isn't sealed and will get road grime in it, that is why they are prone to squeaks and rattles over time.
I cannot verify how people work on their car, I can only tell you what/why failure happens on rubber bushing when improper work practices are followed. If this is not the cause of the OEM bushing failure, it can/will be a cause of a replacement rubber bushing to prematurely fail.
Old 01-06-2010, 03:46 AM
  #63
JasonZ-YA
JasonZ-YA's Avatar
I see what your saying........in doing that job, i never disconnect the lower ball joint, but i sure dont recall having to push "way down" to get the strut out either...was always really easy to pull out and the suspension isnt hanging down horribly.....
that i agree with......sure, i agree it can lead to premature failure, but i doubt its the main cause.....
i think its just torsional loads and wear and tear.....between me and a bunch of buddies all cars ive seen have all gone out at about the 68k-90K mileage range.....sure the 68k car may have had bad suspension work practices to aid in a wee bit quicker translink bushing repair.....
good info john.....is that 30 years working on lotus's?? racing them?
-J
Old 01-06-2010, 04:25 AM
  #64
Z1 Performance
Former Sponsor
I've never had to push down on the lower control arm to get a strut off the front of a Z, or any coilover (I've used over 20 of them). Once the shock is unbolted from the lower control arm, and the upper mounts are loosened, the shock just slips right off easily without any effort. The rear is where that needs to be done, yet the rear bushings don't seem to go bad with any sort of regularity, and people change them out of want, not need.
The factory service manual does not call for removing or even loosening the inner control arm bolt to remove the strut.
Removal and Installation AES0002W
REMOVAL
1. Remove tire with power tool.
2. Remove undercover with power tool.
3. Remove harness of wheel sensor from shock absorber. Refer to BRC-83, "WHEEL SENSORS" (With
TCS), BRC-143, "WHEEL SENSORS" (With VDC).
CAUTION:
Do not pull on wheel sensor harness.
4. Remove mounting nuts of brake hose from shock absorber.
5. Remove mounting bolt and nut between shock absorber and transverse link with power tool.
6. Remove tower bar. Refer to FSU-20, "TOWER BAR" .
7. Remove mounting nuts on mounting insulator with power tool, then remove shock absorber from vehicle.
INSTALLATION
 Refer to FSU-8, "Components" for tightening torque. Install in the reverse order of removal.
NOTE:
Refer to component parts location and do not reuse non-reusable parts.
 Perform final tightening of shock absorber lower side (rubber bushing) under unladen condition with tires
on ground. Check wheel alignment. Refer to FSU-21, "SERVICE DATA"
Old 01-06-2010, 04:44 AM
  #65
JasonZ-YA
JasonZ-YA's Avatar
see that.....i knew i wasnt nutz.......i too dont remember having a hard time ever removing any either........i was beginning to doubt myself here and was thinking im gonna watch that closely next time i do a spring job...
I remember pushing up, getting the lower lug up and over and then bringing the strut out from the bottom...
-J
Old 01-06-2010, 09:18 AM
  #66
johnlotusboy
Originally Posted by JasonZ-YA
Igood info john.....is that 30 years working on lotus's?? racing them?
-J
I have only had my Turbo Esprit for 12 years. I've raced miata's, mr2's and done the Italian car disease in my youth.
The Z is a good daily driver that i refer to as my "Japanese Camaro", it's big and heavy.
Old 01-06-2010, 09:39 AM
  #67
JasonZ-YA
JasonZ-YA's Avatar
ha...ha....i agree......atleast it handles better..
-J
Old 01-29-2010, 04:30 AM
  #68
AcidJake75
Living in 350Z
AcidJake75's Avatar
Thumbs up My Bushing Install - Thnks OP for Great Write up sir..
Look Familiar?
A pic of metal to metal wear since I had to drive it like this for over 3 wks..
Old CRAPTASTIC OEM Bushing
Getting that hoe bag out
New one installed - if you cant tell Im a happy camper
DONE
Win for this DIY since I believe the whole arm costs like 200 bucks.. I got the bushings for 50 bucks (give or take) and labor was all me..
THX AGAIN Z-YA!
Old 01-29-2010, 04:38 AM
  #69
JasonZ-YA
JasonZ-YA's Avatar
WIN! great pics and addition to the thread.....
-J
Old 02-01-2010, 06:28 AM
  #70
ReaganDee
ReaganDee's Avatar
Position 1 - Transverse link to steering knuckle
Jason -- What is the bushing in "Position 1"? My driver side one is SHOT!!
Old 02-01-2010, 06:31 AM
  #71
JasonZ-YA
JasonZ-YA's Avatar
oh, that is a ball joint in the front spindle (you can see the pressed side at the bottom in that pic), when you remove the translink all you see is its cone top.
check with Z1 and see if they have one offered by whiteline...
Courtesy parts.com shows it as the entire knuckle......might wanna call them and see if they offer the balljoint only, if you cant find an aftermarket one:
http://www.courtesyparts.com/350z-pa...5_800_801.html
-J
Old 02-01-2010, 06:56 AM
  #72
Z1 Performance
Former Sponsor
that ball joint is not offered by Nissan/Infiniti nor by Whiteline at this time - perhaps at some point in the future
The one that is offered (we're running it on our cars here, plus on more than a few customer cars) is by Moonface Racing - it repositions the balljoint and includes the associated spacers for the rest of the control arm to put things back on an even plane once installed. Turn in response was remarkably improved after installing it - it was pretty amazing. Requires coilovers (since install will change your height and you need a way to change it back). Been in my car since Fall 2008, and it's worked flawlessly. Upside is it comes complete and nothing else is needed. Downside is cost (it's not cheap!), but Moonface is a higher end firm, and their stuff tends to fall on the expensive side of things.
Old 02-01-2010, 07:19 AM
  #73
ReaganDee
ReaganDee's Avatar
BLAST!!! Just did some more searching and found a thread saying that you have to buy the entire Knuckle ... nobody seems to sell just the bushing
https://my350z.com/forum/brakes-and-...ll-joints.html
Sweet DIY by the way ... gonna check my other bushings this weekend ... So a call to Z1 for some Whitelines might be in my near future if any other bushings arent looking too good
Old 02-01-2010, 07:56 AM
  #74
JasonZ-YA
JasonZ-YA's Avatar
i must say though.........F'n nice!!
https://my350z.com/forum/7717552-post15.html
-J
Old 02-02-2010, 12:30 PM
  #75
specialized5223
specialized5223's Avatar
Jason always has the best damn DIY's. Buy this man a beer!
Old 02-02-2010, 12:33 PM
  #76
JasonZ-YA
JasonZ-YA's Avatar
Old 02-07-2010, 07:27 AM
  #77
twitch579
twitch579's Avatar
Just changed mine out. Bought totally new arms. I got a smoking deal on them so thats why I did it. The other bushing that mounts to the strut was beat down pretty hard also. I also changed all my shocks at the same time too. The car feels stable on the road again, no more scary wobbling at high speeds. Just as stable as a rock like when it was new!!
Old 02-07-2010, 01:16 PM
  #78
Royal_T
Royal_T's Avatar
Man I need to do this bad
Old 02-07-2010, 05:38 PM
  #79
drifter5
drifter5's Avatar
mine are **** too, I took a look at them when my car was on the lift and they were pretty bad.
Old 02-07-2010, 08:40 PM
  #80
JasonZ-YA
JasonZ-YA's Avatar
I see your local....come to the DFW tech day and I will help ya knock it out..
https://my350z.com/forum/meet-ups-ev...-tech-day.html
-J
Quick Reply: DIY - Lower Control Arm Bushing Replacement - Translink
