| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into My350Z.com, click logo to login |
| Register | 370/350Z Photo Gallery | FAQ | Members List | Calendar | Arcade | Search | Today's Posts | Mark Forums Read | Garage | TSB & Recalls | Used Cars | Vendor Directory |
| Welcome to my350z.com! |
Welcome to my350z.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
Thread Tools | Search this Thread |
#1 |
I just ordered a set of KW Variant 2 and I've been trying to figure out how I'm supposed to adjust the rebound setting on the rears. I believe it's a knob on the top of the strut but how are you supposed to access this thing without taking the strut out each time?
__________________
'07 Magnetic Black Grand Touring 6MT-----TrackDays: Thunderhill-4, Buttonwillow-1 |
#2 |
Moderator
Tech & SoCal. ![]() |
my KW Clubsports have a ~2 or 3mm hex bolt on top of the shock to adjust rebound...
__________________
Cheston |
#3 |
is there a way to access that bolt from the trunk or something?
__________________
#4 |
Moderator
pop off rear plastic coverings. and then drill 2 or 3" diameter hole directly over the rear strut.
__________________
Cheston |
#5 |
MY350Z.COM Sponsor
correct ^
__________________
Adam Z1 Performance www.z1auto.com 631.863.3820 AIM:z1auto www.cornerbalance.wordpress.com 320WHP Project Z33 - All Motor - Click! |
#6 |
omg, ic... I don't see much discussions about this. guess most people just set it first, install it and forget about it. Only thing I found is this after searching 'drill hole coilover':
And this is the only pic i found (pic 3) http://my350z.com/forum/brakes-and-s...installed.html That seems like a tricky location to put a socket in or reach in to turn. (SOL if the socket falls off in there) How deep is it from the hole to the adjustment knob? Chebosto, you also drilled the hole in that location?
__________________
#7 |
Moderator
yes. i drilled in that location, however with a MUCH larger hole, and i got an extension for the hex key as not to drop it inside the strut tower framing
__________________
Cheston |
#8 |
JDM 420 Inc.
Or you can have Louie at L-con Race cars do a rear setup similar to mine
#9 |
nice setup and car!
but a cage is a bit over the top for my needs haha. hmm, the adjustment knob isn't as deep in as I first thought, just ~an inch or even less.
__________________
#10 | |
JDM 420 Inc.
Quote:
Yeah, the adjustment knobs are not too deep. My strut bar was drilled as mentioned above by Cheston, prior to the cage. Good luck
#11 |
Ok, got my KW V2s and now i see how to adjust it. Gonna post some pics in case anyone were looking for details on how they're like. Documentation on KW's site isn't quite clear since it shows 3 different types.
Here's a pic of the front coilover and rear strut + springs along w/ the spanner wrenches for each (different diameters) Here's a closer pic of the adjustment knob of the front coilover, use allen key to loosen and turn knob to adjust height. Has a tag that says to tighten 1-2ft/lbs also. Here's a pic of the rear spring. similar idea, but no hole for allen key And here's a pic of the top of the rear strut. Adjustment is done with allen key and "clicks" on turns. The adjustment is done at the TOP, so drilling is required to access! Now, gotta find the time to put them on. Any out there with these or the V3s that would like to share their settings drop + rebound settings (and compression if u got V3s)? Not even sure if many people have these on their Zs, but seems pretty popular on BMWs.
__________________
'07 Magnetic Black Grand Touring 6MT-----TrackDays: Thunderhill-4, Buttonwillow-1 Last edited by zettahertz; 01-29-2009 at 06:45 PM. |
#12 | |
Quote:
Where it say's to only torque the allen key or setting screw 1-2 lbs, do just that, use a very light touch. Using any more force will damage the threads and cause the seat to hang up and not want to turn because of the damage. I would start with 1 turn rebound from full soft and test. The product is make for Kw by Koni, I had no idea that Koni didn't give them the same rear adjustment system where you can adjust them from inside the wheel well. If you'd like, I have to visit the shop that has finally finished my revalved Bilstein coilovers in San Jose on Monday. I'd really like get a shock dyno run on your setup, I am even willing to pay for the dyno's. Seeing the plots would help you know what changes with different adjustments. PM me if your interested. |
#13 |
Interesting, thanks for the info.
__________________
#14 |
Sorry didn't mean to hijack your thread zettahertz
I have mine sitting in the garage forever and haven't put them on yet. I am curious whats everyone V3 setting are? I would like to get an idea that I am playing the rebound and compression correctly. What are you guys running for the street and the track. I think I am finally going to put them on next month ~Robert |
#15 |
^ Robert, I still have my Truechoice Phase IV coilovers which are double adjustable. I did what I thought was right following the suggestion's that Koni and Truechoice publish regarding dialing in a DA shock. After I had them dyno'd, I realized that I was using far too little compression and far too much rebound. Seeing the plots really helped me get much better resluts. If you were willing to send me a single front and rear damper, I'll get them dyno'd for free and pay for return shipping. You'd have the plots within 24hrs of the runs being done. LMK.
#16 | |
Quote:
~Robert |
#17 |
Hi mate, the KW's on mine i have set up like this:
front rebound 4 clicks from full hard low speed bump 5 quater turns from full hard. rear rebound 8 clicks from full hard low speed bump 4 quarter turns from full hard. hope that helps.
__________________
S2K antenna - Varis cooling plate - 35% tint - K&N Typhoon intake (custom heat wrapped) - Dynamat boot floor - 235rwhp DD - Gas bonnet struts - JDM nismo skirts - KW Veriant 3 coilovers - Kenetix HFC - Custom Y-pipe - Nismo V2 oilcap - Custom painted engine cover |
#18 |
OrangeZ
How are the KW v3 feels on the street? How stiff are they? I was deciding between KWv3 and Bilstein PSS10, and I picked PSS10, due to the more complicated adjustments. I do go to track, but I think The more adjustment I have, the more work and confusion I will get. And I dont want to cut open the inside panel either.
My PSS10 feels like stock on softiest setting, ( I heard the KWv3 is very streetable too) however on the track, the PSS10 still feels like a little bit soft. I will post a review on the PSS10 later on. Keep us updated on ur new suspension. Gratz, good work!! -Pat |
#19 |
Thanks to GSedan35 for the shock dyno. He has determined that the best set up for the V2s are 9 clicks (1.5 turns) from softest for the front, and 6 clicks (1 turn) from softest for the rear. And stated that running it at too stiff is pretty stressful on the suspension, perhaps he can put more detail in the explanation. And he'll be receiving the dyno data from the shop owner that ran the dyno.
__________________
#20 | |
Quote:
To be more specific, the recommended settings were based on the spring rates that come with them and a desire to stay within the capacity of the damper. Higher settings may make certain elements "feel" better, but will not be worth the end cost of shorter shock oil life and anthing else that can be damaged by excessive cavitation over the long run. |
| Tags |
| 350z, adjust, adjusting, adjustments, car, choose, coilover, coilovers, diy, kw, pics, v2, v3, variant, video |
