How to install Lower Ball Joints
Old 09-21-2015, 09:37 AM
  #41
CJs_Z33
CJs_Z33's Avatar
Originally Posted by i8acobra
You're not heating it hot enough to do any damage. The heat coming off your brakes makes that cone hotter than the (propane, not acetylene) torch.
It's got nothing to do with automotive training, it's basic metallurgy which I happen to know a bit about as a welder.
Your "factory team training" must not have covered much chemistry or metallurgy. Sounds like they just gave you basic "rule of thumb" advice.
hey aaron are you still at centennial nissan?
Old 09-21-2015, 04:21 PM
  #42
i8acobra
i8acobra's Avatar
Received 1,267 Likes on 1,015 Posts
I quit Nissan. All of my tools are at home now. I make more and get better benefits back at Las Vegas Paving.
Old 09-27-2015, 11:54 PM
  #43
CJs_Z33
CJs_Z33's Avatar
Got my CZP ball joint on. Pulled the whole steering knuckle off and took it to a machine shop to get the old ball joint pressed out and these new ones pressed in. So far so good. Lets see how long these last.
Old 09-28-2015, 02:31 PM
  #44
i8acobra
i8acobra's Avatar
Don't install it like that. You haven't transferred the cone yet.
Old 09-28-2015, 04:11 PM
  #45
CJs_Z33
CJs_Z33's Avatar
Haha i installed the cone before putting the lower control arm on. This is just a pic of it pressed in. What you think im some kinda noobie?
Old 09-28-2015, 04:37 PM
  #46
i8acobra
i8acobra's Avatar
you forget... I worked at the dealership. I've seen all kinds of messed up stuff.
Old 02-23-2016, 12:35 PM
  #47
camposrod
camposrod's Avatar
Since no one could confirm. I went ahead and purchased them anyways. They do come with the cone.
Hi CJs_Z33- what are your thoughts on the CZP ball-joints so far? Decent product?
I need to replace mine before the season starts. I noticed Z1 has a pair too
Old 02-27-2016, 07:09 PM
  #48
CJs_Z33
CJs_Z33's Avatar
So far so good. Boot still in place.
Old 03-04-2016, 04:59 PM
  #49
mr.badratchet
mr.badratchet's Avatar
Default ball joint press pipe bushing solution
I read this thread a few days ago before doing my left lower ball joint today. I, like everybody else found that the the size of the pipe bushings included with the O'reilly rental ball joint press tool were either too small or too large to allow the ball joint to be pressed up into it. So being the master of improv that I am I searched the garage and tried a number of old hub bearing races, misc pipe, etc. and finally found the solution.
I used a 2" electrical conduit pipe coupler with the O' BJ press "C" clamp. It's perfectly sized ID and OD except I just had to use a small grinder wheel on the drill and take of the top of the threads. The old and new ball joints fit perfect. $4 and no trip to Harbor freight for their cheap press master bushing set (they didn't have one in stock anyway) or being ripped a new one by a machine shop to do it.
I spent way more time trying to solve the dilemma than it did to actually do the job.
In the end it's all good, and cheap. Oh BTW the only place local I could find that had a ball joint (came with cone) was Auto Zone (duralast brand) for ~$50
Old 03-08-2016, 02:26 PM
  #50
DRELOC
DRELOC's Avatar
Did you install wheel bearing also while the knuckle is out? Seems easy that way
Old 03-21-2016, 11:29 PM
  #51
CJs_Z33
CJs_Z33's Avatar
have not done wheel bearings yet. mines are fine.
Old 04-04-2016, 09:22 AM
  #52
rizeld
rizeld's Avatar
How many miles have you driven so far? Both of those failed on my Z with 1200 miles. I could be that 1% that gets the 1% failure rate on parts (which seems to be the norm for me).
Old 04-04-2016, 12:54 PM
  #53
CJs_Z33
CJs_Z33's Avatar
Ive put about 5k miles since then.
Old 04-23-2016, 04:42 PM
  #54
Bak3rme
Bak3rme's Avatar
CJs, how much did the machine shop take from you to press the old one out and new one in? I have my knuckle off the car and was going to bring it in to them.
Old 04-24-2016, 11:23 PM
  #55
CJs_Z33
CJs_Z33's Avatar
every machine shop will have their own price. I think i paid 80 to have these ball joints pressed into the knuckle and whiteline bushings pressed into the lower control arm.
Old 04-25-2016, 06:11 AM
  #56
Bak3rme
Bak3rme's Avatar
Thanks CJ. Just needed a ballpark number. Did they do fine with the lower control arm bushing? I known u need a frankensocket to press it in.
Old 04-27-2016, 04:33 PM
  #57
tyau
tyau's Avatar
Do you mind taking a picture to show us how much thread engagement the ball joint threads and the nut have after you installed the control arms?
Old 04-29-2016, 10:21 AM
  #58
CJs_Z33
CJs_Z33's Avatar
I can but it looks just like stock. I was able to slip in a cotter pin at the end and it comes with a castle nut so it holds the cotter pin good.
Old 04-29-2016, 10:28 AM
  #59
CJs_Z33
CJs_Z33's Avatar
Not sure what they used, but its a machine shop. they have all sorts of adapters and if they dont have one, they fabricate one. Some places are scared to touch aluminum, but this guy did a great job pressing everything in.
Old 05-01-2016, 09:16 AM
  #60
CJs_Z33
CJs_Z33's Avatar
well after 8 months the passenger side lower ball joint boot decides to rip...
Quick Reply: How to install Lower Ball Joints
