Aggressive camber For noobs help !
Toasty
This doesn't make much sense to me. Isn't extreme negative camber only an issue when it minimizes the contact patch to a dangerous level?
If I have fresh, high quality summer tires, let's say 255's, with just enough camber to be illegal, is it any unsafer than some piece of crap econobox with some 155mm wide budget tires on it at factory camber? Unless I'm at ridiculously overboard camber settings, the high negative camber setup with beefier tires will have more contact patch than some other vehicles out there. The legality should be dependent on contact patch, not camber angle
Just for the record, I'm not one of these camberqueers. I'm a fan of functional setups within factory spec and/or track oriented setups with proper fitting tires as evident by my own personal setup. Just making this argument in the interest of logic.
Toasty
I get where you're coming from, but with camber like the one in the pic, you have side wall issues, you have steering response issue, assuming the front is camber the same. To me, that much camber should be illegal. It's not just contact patch, but the thread design has an enfluince on the handling characteristic of it.
I think the sidewall issue is more a function of tire width relative to wheel width (ie how stretched the tire is), which should be illegal at a certain point. However this factor wouldn't be indicated by simply measuring camber angle. I agree with the principle that these law enforcement agencies have who are targeting the hellaflush crowd, but I think they are addressing it wrong. They should be focusing on tire stretch more than camber to be honest.
Thanks a lot for the info. I'm already maxed on my coils for the most part so yes I have "natural" camber but it's nowhere near -6 I'd say about -3 if I had to guess and I haven't seen a single rear camber arm that goes past -3/-4. I.e. Megan,spl, spc, kinetix. And I have a true coil set up for my rear so I don't utilize the spring bucket
And your natural camber may look like its -3 to you because all the cars now run -8 and above but trust it is probably around -5 through -6
