Brake Master Cylinder question
on
Ok thanks. I did a bench bleed of the MC to start with and what I thought was a pretty good job of bleeding the system. But I'm not sure if a poor bleed would cause the pedal sinking issue, thought it would be more likely to cause a "mushy" pedal instead.
I'll try another bleed and see how that goes.
Wyv (10-23-2015)
on
Ok today I took the long way home and found some shingle. After giving the ABS a bit of a work out the sinking pedal is gone. It's still not as firm as I would like but at least that seems to have narrowed it down to the bleed. Fingers crossed!
Might buy a power bleeder and give that a go, I'll post the outcome on here.
Thanks guys.
Thanks guys.
Very good idea getting the ABS to cycle. I think that's what the dealers do with their diagnostic computer. Definitely get a pressure bleeder - one of my most useful tools, and not only do you get a better bleed, but it also save a lot of wear on the MC bore and seals from multiple full strokes of the piston during a pedal pump bleed.
Thanks guys.
Thanks guys.
Can't wait to remove my ABS unit
