High Clutch? want to lower your clutch engagement point?
Old 02-04-2009, 05:55 PM
  #401
candyman7
candyman7's Avatar
Old 02-08-2009, 01:42 PM
  #402
jkebun
jkebun's Avatar
i followed the instructions and adujusted my clutch. before, the engagement point was close the the ground. i couldnt even get 2 full clockwise rotations cuz the rod stopped turning, and now engagement point is extremely high. i only have to push in maybe 35% of the way down to shift. it seems like i got the opposite effect lol... but at least its less sticky when the pedal is coming back up. should i go counter-clockwise and see what happens? i got barely any thread showing too. so confused... im going go play around with it for a bit. my back hurts just thinking about it.
Old 02-08-2009, 03:01 PM
  #403
eat rice z33
eat rice z33's Avatar
Update: my adjustment is still going strong. Yes i had to fiddle a little with it to get it just right but worth it in the end!!
Old 02-12-2009, 12:38 AM
  #404
jkebun
jkebun's Avatar
update: for me, i had to turn the rod counter-clockwise to lower it. feels great now.
Old 02-13-2009, 08:33 AM
  #405
saint365
saint365's Avatar
my friend drove my z yesterday, he was shocked that my clutch engagemen point was too high comapre to his hoda accord. this is def good mod I'm doing during good weather.
Old 02-18-2009, 10:24 PM
  #406
victor1
victor1's Avatar
thanks!
Old 02-26-2009, 01:33 AM
  #407
ClaZ
ClaZ's Avatar
Default It's not so much the clutch that you have to worry about wearing out...
...it's the synchros!
Old 02-28-2009, 01:07 PM
  #408
JAbraham03
JAbraham03's Avatar
i did this mod about a week ago. Drove it and tested it to see if it had a weird smell. After a week I started to get a smell when I turn off the car. Couple questions. Am I riding the clutch too much or is this mod affecting it? The clutch is fully disengaging though. I checked and the cylinder is all the way out so it is not riding around with the clutch slipping. Any ideas what the smell would be? Either seems to be the clutch, brakes or tires. Is a burning smell though.
Old 08-22-2009, 03:09 PM
  #409
formulaben
formulaben's Avatar
Thanks for the tip!! Adjusted both the clutch and the Cruise Control/Pedal Stop...MUCH BETTER!!
I tested the CC to make sure it worked. Wish I had done this earlier!!
Old 08-22-2009, 04:06 PM
  #410
formulaben
formulaben's Avatar
Originally Posted by 1 2 NV
does anyone remember how many threads were showing before adjusting?
I'm sure you no longer need this info, but someone else might. I saw 2 threads out the open end of the fork bolt before, now there's 4. Huge difference. I'm guessing the clutch failures are due to over-adjustment.
Old 01-26-2010, 12:20 PM
  #411
sry110
sry110's Avatar
Rise from the dead, thread!
Has anyone tried the DIY method that redlude97 posted a few pages back? Looks to me like it removes the "free play" at the top end of the clutch travel, as well as some excess travel (I'm assuming) at the bottom end of the clutch travel, beyond the clutch engagement point. Net result is less clutch pedal travel, while not actually altering the clutch engagement point. Any thoughts or first-hand experience?
Here is redlude97's link from before:
http://g35driver.com/forums/showthread.php?t=168519
EDIT: The only downside I see to the DIY posted in this link is if the stopper underneath the lever is too thick and does not allow the clutch to come fully disengaged when you press the pedal down.
Old 01-28-2010, 05:26 AM
  #412
sry110
sry110's Avatar
BUMP
Anyone try this? Thanks...
Old 02-03-2010, 07:54 AM
  #413
Dr. Venture
Dr. Venture's Avatar
Old 02-03-2010, 05:32 PM
  #414
semcnf03
semcnf03's Avatar
BUMP
https://my350z.com/forum/engine-driv...lutch-kit.html
I just did this today - feels so much better, the engagement point is much easier to find. It's such a stupid easy fix that actually delivers. Best $5 and 5 minutes Ive spent.
Old 02-04-2010, 10:07 AM
  #415
zrzly?
zrzly?'s Avatar
just did this cuz I was bored, as far as difficulty and benefit, this "mod" has the highest benefit to cost ratio lol. did anyone ever give official feedback on how over adjusting can wear down clutches/syncros as mentioned before? I don't think I disengaged it, because the clutch still disengages and gears shift a bit better although I think that might be just the placebo effect.
Old 02-04-2010, 07:33 PM
  #416
Steve-O Z33
Steve-O Z33's Avatar
Lowered mine a little bit about a year and some change ago. No issues yet. Stock clutch is still fine.
Old 02-04-2010, 11:10 PM
  #417
Synjn
Synjn's Avatar
After 3 turns I got it to my preference. Only thing concerning me is the pedal doesn't pop all the way back up and I don't want my throw out bearing constantly engaged just by the weight of the pedal. Or is this just my imagination?
Old 02-12-2010, 09:04 PM
  #418
ZKansasZ
ZKansasZ's Avatar
you need to read through the 20 pages thread before asking the same question as they have encountered over and over again, bud!
Old 02-14-2010, 05:42 AM
  #419
y0k0m0
y0k0m0's Avatar
anyone done this on a RHD Z got any tips as i cant even see the locking nut let alone get a spanner in there !
Old 02-17-2010, 05:03 PM
  #420
dproto09
dproto09's Avatar
synjn, i did the same thing you did. This is just a warning to all...you are going to be driving the car and the clutch is going to have slippage with that adjustment. your going to start burning your clutch i hope you back it off. i notice it on my car, drove like that for 2day, and i would smell the clutch after getting out the car.i fix it and only went 1 turn to be on the safe side So far everything good, no smell... The clutch level must go all the way up. at that lower engaugement point the spring on the clutch pedal doesnt have enough leverage to pop the spring all the way up. That why your pedal doesnt pop back up. Post #413 is the best advice i seen to set your factory clutch properly
Quick Reply: High Clutch? want to lower your clutch engagement point?
