Another Custom Grounding Kit: Pics and Instructions
Old Feb 15, 2003 | 01:30 PM
principe's Avatar
principe
Default Installation
Thanks for the info, do you have any info on the install .. I seem to recall a thread on it but I haven't been able to locate it.
Thx
Old Feb 17, 2003 | 04:28 PM
Purdone's Avatar
Purdone
Hi, I'm new to Z's, and the 3.5 liter V-6. I was wondering if someone would explain the principles behind a grounding kit. How does it work? Thanks!
Old Feb 17, 2003 | 07:06 PM
jackwhale's Avatar
jackwhale
Look at the other thread started by insaneamine which gives info from a variety of people about grounding kits. I was skeptical and then I talked with two other Z owners at an autocross race. They had just installed the grounding kit and felt that it made a difference. Like any true follower, I bought one from insaneamine. I agree with redline that there is a difference at higher rpms. It certainly isn't a necessary addition but.....
Old Mar 17, 2003 | 03:44 PM
jamiez's Avatar
jamiez
Default grounding kit
whats the grounding kit really help?
Old Mar 17, 2003 | 04:56 PM
vics350's Avatar
vics350
Jamie, Andrew (rouxeny) installed grounding wires in his car and we instantly noticed that the engine felt smoother when shifting. Also, it seemed to be idling a little less than before the install. After driving his car and then getting in mine, I noticed that the engine in my car sounded a little rougher when shifting than his did.
If Andrew is free, he will be going to Nazar's meet. If you plan to be there you can check his out then.
Old Mar 17, 2003 | 06:33 PM
blaque's Avatar
blaque
Did you have to take the strut bar out? I noticed this bolt on the upper right hand corner of the engine cover that's directly below the strut bar. How did you guys reach that one
Old Mar 17, 2003 | 06:41 PM
slaponte's Avatar
slaponte
Default No, you DO NOT take the strut out!
The bolt clears under it. I used a long open-end wrench and when it gets loose, just slide to finger under and slide it out (uhh, sounds kinky!).
Don't drop it. Thats the worst that can happen during the install, to go chasing screws under the engine...
Old Dec 12, 2006 | 06:26 PM
Chad68's Avatar
Chad68
this will help too
Never mind me Im just replying so I dont loose this thread
350Z_Al
Oct 29, 2020 07:44 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
