Rear End Noise.
Old 03-03-2017, 05:46 PM
b1g_johnn
b1g_johnn's Avatar
Default Rear End Noise.
I've looked around the forums and google and checked if anyone has the same issue as mine and I found nothing.
Cars rear end starting to make this steady clunking noise during acceleration, right around 3000 RPM (16-17 MPH). It sounds like someone is lightly tapping the chassis behind the driver seat. Clunking noise gets faster when accelerating, but after reaching speeds (30 or above) clunking sound seems to vanish...
Has anyone every encounter this type of problem?
Old 03-03-2017, 07:21 PM
carbuffguy
carbuffguy's Avatar
maybe this?
https://my350z.com/forum/maintenance...noise-fix.html
Old 03-04-2017, 08:43 AM
b1g_johnn
b1g_johnn's Avatar
Originally Posted by carbuffguy
Sadly no.
Old 03-05-2017, 07:10 AM
travlee
Master
travlee's Avatar
Received 9,049 Likes on 6,515 Posts
Check rear subframe, does the bushing that the diff attaches to, have black goo or lines going down the subframe
Old 03-05-2017, 11:36 AM
b1g_johnn
b1g_johnn's Avatar
Ill go check it next weekend!
Old 03-06-2017, 04:24 PM
Surfer90291
Surfer90291's Avatar
Check the drive shaft bolts, I had a similar problem, tightened back up and now it's gone. My oem rear diff bushing is shot too, I thought it was the main responsible for the noise but I was wrong.
