FS: Built VQ part out, some OEM
For sale is a Z1 Motorsports built VQ35de that includes.
Z1 Motorsports' "Stage 2" VQ35 Performance Shortblock Includes:
Engine block fully disassembled and cleaned
Block bored and honed to proper piston to wall clearance
Block decked and squared
Z1 Specific Wiseco Forged Pistons (8.8:1 CR)
Eagle Connecting Rods
Cosworth Race Bearings
ARP Main Studs
Completely balanced rotating assembly
Z1 Motorsports' "Stage 1" VQ35 Performance Heads Include:
Heads Disassembled & Cleaned
Heads resurfaced & stamped with amount removed
Valve Guides Checked
Z1 Viton Valve Stems Installed
Valves checked and replaced as necessary
Stock valve job (High flow radius cut with bowl work available as an option below)
Valves installed and lapped in
Valve stem height checked & proper cam to lifter clearances set
Combustion chamber leakdown test ensures less than 5% leakdown past fresh valve job
High Flow Radius Cut
This motor has 0 miles on it, it was assembeled installed and never ran. It also has ARP L19 Headstuds and HKS Headgaskets.
Longblock price is SOLD!
Also pictured is a set of BC Stage 2 Cams 0 Miles SOLD!
Rev up oil pump 0 miles SOLD!
Water Pump 0 miles SOLD!
Also pictured are various OEM parts, these parts have 47,000 miles on them.
- Valve Covers SOLD!
- Starter $50
- Altenator $50
- Plenum SOLD!
- OEM Cams $35
- Crank Pulley $35
- Throttle Body $65
- Coil Packs $85
- Valve Timing Solenoids $25ea.
- Front timing cover $55
- Rear Timing Cover $45
- Upper Oil pan $75
- Driver Cam position sensor $35
- Rear coolant pipe $25
- Timing Chain with tensioners and gears $75
- Intake Manifold SOLD!
- AC Compressor $45
I also have the main engine harness (not pictured) $125
ARP Main Studs
- Starter $50
- Altenator $50
- Plenum SOLD!
- OEM Cams $35
- Crank Pulley $35
- Throttle Body $65
- Coil Packs $85
- Upper Oil pan $75
- AC Compressor $45
