OEM TPMS or aftermarket Sensors?
Old Oct 3, 2024 | 08:22 AM
CFAUVEL's Avatar
CFAUVEL
Default OEM TPMS or aftermarket Sensors?
I think the back two sensors have deenergized batteries as I read 0 psi on one wheel and varying psi(from 15 to 50 psi) on the other wheel.
Should I get the OEM sensors at about $100 each or go with an aftermarket set...and if aftermarket do you all have a recommended brand that plays nice with the TPMS programming tools most shops use?
Old Oct 3, 2024 | 05:22 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Autel. $69/wheel installed and programmed at Pep Boys.
Old Oct 4, 2024 | 04:44 AM
Aeneas137's Avatar
Aeneas137
Yes like the previous poster suggested, the TPMS is standardized so you won't run into problems with one OEM functioning differently from others. I paid $60 per wheel and discount tire / America's tire when I bought new wheels. mainly because I just didn't want to pull off the old tires from the set to sell them. secondly, it's nice to have new transmitters after 20 years.
Old Oct 4, 2024 | 05:14 AM
iideadeyeii's Avatar
iideadeyeii
I could only assume the cheaper sensors would have cheaper batteries and not last as long.
Old Oct 5, 2024 | 08:30 AM
Aeneas137's Avatar
Aeneas137
cheaper than what, OEM? do you realize that car manufacturers use thousands of parts from different companies? there's no such thing as a Nissan TPMS transmitter. but do what you want....
Xx AzN xX
Wheels Tires
May 28, 2015 07:24 AM
350zzl
Mar 24, 2011 11:39 AM
cpatel529
Wanted
Mar 14, 2011 12:56 PM
cbeneke
Sep 12, 2008 06:38 PM
