Sponsored by:
Sponsored by:
How do i disable driverseat air bag?
Old 04-11-2007, 09:50 AM
MrKaira
Really MrZ31
MrKaira's Avatar
this might sound stupid, but i can't get it to work.
i tried the method of just plugging the resistors into the plugs and then doing the reset procedure, but the light continues to blink.
My first question - does it have to stay in diagnostic mode for any particular amount of time?
Second question - is one 2.2 ohm plugged into the old plugs enough?
I would rather not cut and splice, but will as a last resort.
Any help is appreciated.
Old 04-11-2007, 10:09 AM
Chebosto
Chebosto's Avatar
i just entered the diagnostics mode. and checked the blinks on the ABS to get the all clear signal. then went back to user mode.
2.2ohm.. hm. might be on the high side-- you could do the 5 resistor in parallel trick and solder all the ends together and plug it into the clip. should work- too. just tape it in place so it doesnt come out.
Old 04-11-2007, 10:29 AM
MrKaira
Really MrZ31
MrKaira's Avatar
so what does the all clear blinking in the diagnostics mode look like?
Old 04-11-2007, 11:32 AM
Chebosto
Chebosto's Avatar
See B-lo
Old 04-11-2007, 05:48 PM
SlipZ
SlipZ's Avatar
Originally Posted by Chebosto
should work.
for those in the LA Area- Fry's electronics sells 1ohm resistors, you could get two in series to get the same effect.
driver steering wheel uses dual 1.7ohm resistors.. in which dual 2.0ohm resistors would probably work as well..
i have all the parts now, there are 3 leads (wires) from the passenger side connector. I think its a air bag disable for the passenger below minimum weight.
where do i connect the 2 ohm resistor? which ones on the 3 leads (wires)?. I have not connected yet b/c i want to make sure where to connect it.
update: i called www.airbagonoff.com (bob brown) i was told that he has not made any resistor bypass air bag kit that will include weight sensors for 06-07 Z's.
im really stuck now!
Old 05-03-2007, 08:19 AM
MrKaira
Really MrZ31
MrKaira's Avatar
UPDATE:
Just wanted to let anyone know that read this thread that I went and bought 2 packs of the resistors Chebosto recommended, and got a solerding kit.
I soldered all the resistors from on pack (turning 5 into 1) and did that twice, plugged it in, did the reset procedure, and now no more blinking light.
My problem was the resistors, so make sure you have the ones that he recommended and you can plug them in, you don't have to solder the resistors into the wires, but that might be a more secure option.
For those of you that have never soldered before it really isn't hard. This was my first time and I didn't have any problems.
Thanks again Chebosto!
Old 05-03-2007, 09:03 AM
Chebosto
Chebosto's Avatar
UPDATE:
FTW!
Old 05-06-2007, 10:46 AM
rijowysock
rijowysock's Avatar
well noone in orlando has the right resistors they all have 2.2k or etc (wrong ones) i just bought another nismo harness for passenger side now.. and chebosta.. just lemme know whats what on the weight sensor if u want the pdf of the manual.
at least with 2 nismo harness' the light wont blink but my passenger will not have airbag because weight sensor
riley
Old 02-07-2008, 09:31 AM
streetxtreme
streetxtreme's Avatar
what resistance does the side CURTAIN airbag use?
Old 02-07-2008, 02:27 PM
Chebosto
Chebosto's Avatar
did u try a 2.0 ohm?
Old 04-15-2008, 09:57 AM
MrKaira
Really MrZ31
MrKaira's Avatar
new car, new problems haha.
I did everything exactly like I did before, went and got the exact resistors, soldered them together - plugged them in, didn't work. Did the tap splice, they still won't work.
I didn't think it would make adifference, but I used 14gauge wire because thats what I had. That is the only thing different, do you think that would make it not work?
Old 04-15-2008, 01:36 PM
Chebosto
Chebosto's Avatar
wire gauge? not really.
what year car?
Old 04-15-2008, 02:38 PM
MrKaira
Really MrZ31
MrKaira's Avatar
what year car?
I didn't think so...
2004.5, enthusiast
Old 04-16-2008, 12:19 PM
Chebosto
Chebosto's Avatar
i'd use a multimeter and test to see the total resistance of what u made and reinstall. probably just a bad connection during your splice-
Old 04-18-2008, 07:40 AM
MrKaira
Really MrZ31
MrKaira's Avatar
I guess the radio shack here is just lame, they didn't have a multimeter. Any other suggestions on where to find one?
Visually everything checks out. Its all tight, all connections look good. I can't figure it out.
I am overdue on inspection and can't get a passing inspection until I get that fixed. I wouldn't even know where to begin to take it to have someone look at it. Any suggestions on that?
Old 04-18-2008, 01:52 PM
type59
type59's Avatar
i dont have a z but i was reading on the g forum to get my airbag light off.
what i did was buy a variety pack at radioshack. think it was 12 bucks or something. it has to have a 2.2ohm (comes with 5 in my pack). it has 2 red strips and 2 gold ones. all i did was bend the ends and plug it in. didnt have to reset anything. no more blinking light.
Old 04-18-2008, 01:54 PM
type59
type59's Avatar
rijowysock also has a thread on the g forum to get the around the weight sensor thing. hope that works on my car too...
Old 04-18-2008, 11:30 PM
  #38
white323nismo
white323nismo's Avatar
Would anyone know how to bypass the airbag light on the driver's seat off of the 2007 350z? I tried the nismo airbg harness at the dealer but the item didnt plug into? I understand there is a weight sensor as well.
thanks
Old 04-19-2008, 09:49 PM
  #39
Chebosto
Chebosto's Avatar
2004.5 didn't have the weight sensors in the seat. i thought that was only 05.5 or 06+. white323nismo : you're gonna have to remove the weight sensor in your seat and roll it up to put pressure on it to fake the car thinkin they're always someone in the seat -
multimeter or ohm meter, i think you can find at electric stores, maybe even home depot.
if you happened to turn the car on before you put in the resistors. you'll have to run the SRS reset procedure. try it twice. i couldnt get the timing right the first couple of times, but it ends up working.. when you get into the diagnostics mode, read off the #s to see if its really that airbag you're trying to disable. (it should blink a certain number of times)..
Old 04-20-2008, 10:38 AM
  #40
MrKaira
Really MrZ31
MrKaira's Avatar
Sorry to edit your post, but I didn't think that post even warranted a response.
Hmm ok, I'll give that another try. The attachment above doesn't have that diagnostic information, like how to read which airbag is malfunctioning. Do you have a link to where I can find that?
Quick Reply: How do i disable driverseat air bag?
