Pulled My Motor!
Old Mar 4, 2006 | 03:03 AM
Quamen's Avatar
Quamen
Default Pulled My Motor!
I stayed up all night and pulled the motor out of my car. Everything is out and I am tearing the engine down right now. just wanted to let everyone know.
Old Mar 4, 2006 | 03:10 AM
taurran's Avatar
taurran
Old Mar 4, 2006 | 05:08 AM
Zilvia's Avatar
Zilvia
yeah lets see the beast
Old Mar 4, 2006 | 05:12 AM
Quamen's Avatar
Quamen
I will try to get some pictures up today. Anyone have any suggestions as to how to get the timing cover off with all of that gasket sealer on it?
Old Mar 4, 2006 | 05:25 AM
EM-EFER's Avatar
EM-EFER
yes... work off the two notches on top to break the top of it loose.. then go around the entire timing cover jimmy'ing it to pry it loose and break the sealant.. i worked from top to bottom once of you meet both side at teh bottom it should pry right off.. dont forget to loosin the upper oil pan bolts as well
Old Mar 4, 2006 | 05:33 AM
Quamen's Avatar
Quamen
Just be looking in the hole in the block a piston is compkletely gone (and in the oil pan in a million pieces), the rod is bent and broken, and a valve guide is cracked. Im still trying to get the timing cover off.
Old Mar 4, 2006 | 05:37 AM
EM-EFER's Avatar
EM-EFER
its a ***** to get it off when its in the car... its not bad with the motor out of the car.... TAKE SOME PICTURES!
Old Mar 4, 2006 | 06:37 AM
Quamen's Avatar
Quamen
I cant get it to come loose near the crank at the bottom of the cover.
Old Mar 4, 2006 | 06:39 AM
Quamen's Avatar
Quamen
do i have to punch the dowel pins in at the bottom left and right?
Old Mar 4, 2006 | 06:40 AM
EM-EFER's Avatar
EM-EFER
noooooooooooooooooo dont do that... just keep jimmying it.. its take a little force... it will pop right off.. Just dont over stress is, it could crack
Old Mar 4, 2006 | 06:50 AM
Quamen's Avatar
Quamen
I dont need the bottom half of the engine off do I?
Old Mar 4, 2006 | 07:10 AM
EM-EFER's Avatar
EM-EFER
You need to loosen the upper oil pan bolts torwards teh front.. theres two of them.
Old Mar 4, 2006 | 07:21 AM
Quamen's Avatar
Quamen
Thanks
Old Mar 5, 2006 | 04:21 PM
Quamen's Avatar
Quamen
Here are some pictures.
Old Mar 5, 2006 | 05:27 PM
overZealous1's Avatar
overZealous1
dang bro, you did alot of work. just an fyi, you can get the motor out with out even removing the radiator. it is close but i have done it.
i need your block, lol. wonder what shipping would be.
Old Mar 5, 2006 | 06:07 PM
G352NV's Avatar
G352NV
Scott I have heads and a block for you. Just take another drive. Its 8hrs. While your at it drop off my exhaust.
Quamen's Avatar
Quamen
I took everything off because I am getting a tubular front end made to locate the new radiator, intercooler, oil cooler, and transimission cooler while eliminating the composite radiator support and front crash brace.
Old Mar 5, 2006 | 06:08 PM
Quamen's Avatar
Quamen
I am still really torn on what I am gonna get done to the car now as in engine and FI
Old Mar 5, 2006 | 06:31 PM
overZealous1
hmm, i will give you a call on it steve. i don't want to get creamed on shipping them as i just need the block to test and make sure it will fit in one of the cnc machines for project "brick s#^t house block" lol
Fixxxercask
Nov 9, 2015 11:10 AM
