HKS FCon Pro "Boost Controller"
Old Mar 26, 2007 | 07:56 PM
CESAROTORRES's Avatar
CESAROTORRES
Default HKS FCon Pro "Boost Controller"
Hello Everyone,
Do I need to buy a boost controller if I purchase the FCON Pro? Any advice will be higly appresiated.
Thx
Cesar
Old Mar 26, 2007 | 08:15 PM
Zivman's Avatar
Zivman
Originally Posted by CESAROTORRES
Hello Everyone,
Thx
Cesar
yes -
I would recommend the HKS EVC VI or V, Blitz SBC ID, or Apexi AVC-R
Old Mar 26, 2007 | 09:47 PM
acg's Avatar
acg
Sam installed a HKS EVC VI in mine also.
Old Mar 26, 2007 | 11:32 PM
Nitrouz's Avatar
Nitrouz
Back to Z
+1
Old Mar 27, 2007 | 12:13 AM
GTM's Avatar
GTM
Vendor - Former Vendor
HKS EVC FTW!
-George
Old Mar 27, 2007 | 06:30 AM
Zilvia's Avatar
Zilvia
yea the HKS EVC if you can find one.
if not the Apexi AVC-R is also a good choice
Old Mar 27, 2007 | 08:32 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
the new HKS
EVC..all way. Nice improvement over the last gen.
Old Mar 27, 2007 | 08:43 AM
Zilvia's Avatar
Zilvia
how much does the new EVC run
Old Mar 27, 2007 | 09:32 AM
Zivman's Avatar
Zivman
I think around 600-650
Old Mar 27, 2007 | 11:00 AM
Sharif@Forged
Forged Performance
Sub $600 range.
Old Mar 27, 2007 | 11:50 AM
GTM's Avatar
GTM
I use the EVC6, while the EVC5 was much easier to use the new functions of the EVC6 are great, It took me a while but now I know that BC in and out. As far a functionality they both preform the same, just the new EVC 6 has much more features.
-George
Old Mar 27, 2007 | 12:04 PM
gringott's Avatar
gringott
The F-Con can't control boost???
Old Mar 27, 2007 | 12:07 PM
MIAPLAYA's Avatar
MIAPLAYA
Not directly no. At least its not listed on HKS' site...
Old Mar 28, 2007 | 08:53 PM
CESAROTORRES
Default FCON and TCS/VDC
I just find out that if I purchase the FCON I am going to lose the TCS/VDC and cruise control does not work THRUE or FALSE?
THX
Cesar
Old Mar 28, 2007 | 08:59 PM
Nitrouz's Avatar
Nitrouz
Back to Z
THX
Cesar
They all can be wired to function normally.
Old Mar 29, 2007 | 02:46 AM
gringott's Avatar
gringott
Don't know if the Fcon works like the utec, but in my case with the utec, the VDC does have some problems, at least it seems so, as it cannot cut fuel (or so it seems) so when I break traction in the rear the VDC uses the brakes to control "fishtailing" but since it cannot control fuel, the compensation is not perfect (it is only using brakes to my knowledge) and I get a side to side "wiggle" that was not present without the utec. I would assume the FCON would work the same, unless it has a provision to "cut fuel" based on the VDC signals.
Old Mar 29, 2007 | 07:16 AM
Sharif@Forged
Forged Performance
THX
Cesar
False. The FCON harness, as it sits, will maintain cruise and traction control features 100%. Some tuners will elect to rewire the TPS, in order to get a slightly more stable throttle signal to the FCON.
It really is your choice. All the cars we do, maintain cruise and TCS.
Old Mar 29, 2007 | 08:17 AM
CESAROTORRES
Default Thank you for the Info Sharif
Thank you for the Info!
Sharif you are really a true NERD
Cesar
Old Mar 29, 2007 | 09:54 AM
gringott's Avatar
gringott
What about VDC? FCON takes the throttle cut signal from the OEM ECM and cuts fuel accordingly? TCS and cruise control I understand, VDC is the issue I am wondering about.
To my knowledge, which of course is limited, TCS is a crude version of VDC. VDC uses various sensors, including a gyroscope, to stabilize the car, using braking and fuel cuts. I think they (TCS and VDC) are two different animals. If you will remember from back in the day, there was debate if VDC could even be used with FI, with some companies and/or tuners saying it had to be turned off (due to the fuel cut issue). This was one reason I hesitated before going to a "piggyback" or replacement EMU, because I knew that I would be losing, at least partially, the benefits of the VDC system that I paid for.
I would find it very interesting if it is true that the FCON maintains full VDC function, and would definitely think about switching from the UTEC if that is a fact. I would think HKS would play this up if it were / is true, because that is a great selling point (maintaining full VDC function).
Old Mar 29, 2007 | 10:25 AM
Sharif@Forged
Forged Performance
TCS and VDC is maintained. Remember, that with TCS and VDC, the stock ECU controls the TB angle, in order to reduce throttle inputs and prevent spinning. The ABS side of the VDC works normally too. It all works!
