Finally!! It can be done..
Old 05-16-2009, 05:40 AM
TheMinel
TheMinel's Avatar
very nice! Exactly what I'm going to be having done! 2 gauges where you put them, keep the stock multi gauge, then I still have to decide what to do with the A/F gauge and the remaining Defi gauge, one problem I might have is that I have all 3 Defi's 52mm size while the AEM one is larger... gauge pillar seems like a solution, but the 2 gauge sizes might cause a little issue there
Old 05-16-2009, 05:45 AM
flynbrin
flynbrin's Avatar
great job
Old 07-15-2009, 07:47 AM
FineWine
FineWine's Avatar
What gauges are those? They're beautiful
Link?
Old 07-15-2009, 08:10 AM
MI 35th
OGPremierMafia
MI 35th's Avatar
STRI SLM II Smoke Amber Gauges.
Old 07-15-2009, 08:26 AM
FineWine
FineWine's Avatar
52mm, correct?
Old 07-15-2009, 11:42 AM
midz350
midz350's Avatar
No, they are 60mm.
Old 02-12-2010, 10:44 PM
xzotklr
xzotklr's Avatar
The DEFI BF series are 60mm.
Old 02-14-2010, 12:35 AM
TheMinel
TheMinel's Avatar
yeah I've since found out, had to do it this way
Old 02-14-2010, 02:04 PM
MDK
MDK's Avatar
Why not use a multi-gauge or two? The PLX gauges actually fit inside the housing; it looks completely stock.
Old 02-17-2010, 05:04 AM
MR RIZK
MR RIZK's Avatar
If you dismantle the 60mm defi gauge and remove the silver bezel, modify the rear aluminium cup (be cautious as there is a tiny ground spring) and reshape the inside of the oem cowl you can get the gauge to sit behind the factory silver bezel for the true factory look as what I did on my Z.
Old 02-17-2010, 06:01 AM
o2sys
o2sys's Avatar
km/h speed looks crazy! all those three digit numbers crammed in haha...
i only wish the lighting matched the oem or vise versa.
Old 02-17-2010, 05:42 PM
UpstateNismo
UpstateNismo's Avatar
Those guages look awsome in there.
Old 04-21-2010, 10:38 PM
_ink
_ink's Avatar
Which size PLX fits inside?
Old 07-23-2010, 01:10 AM
ffwturboZ
ffwturboZ's Avatar
I was searching around in hope I find this. So I had to bring it bad to life. I have 2 AEM 2 1/8" gauges (Wideband and Boost) I want to fit in the stock gauge location. Will I have to mount them from the inside without the bezel or can they be mounted the same as it would be on a A-pillar gauge pod?
Old 07-24-2010, 05:07 PM
JustinTime
JustinTime's Avatar
nothing new. This has been my setup for a long time.
Old 07-24-2010, 06:45 PM
y0shi
y0shi's Avatar
how did you separate the first two gauges? They are mounted on the same circuit board.
Old 07-24-2010, 07:52 PM
midz350
midz350's Avatar
I didn't touch the circuit board.
removing the black housing will clear enough space to mount the gauges.
Old 07-25-2010, 01:51 AM
  #38
ffwturboZ
ffwturboZ's Avatar
Do you ave any pics? I would like to keep the factory computer gauge and install the boost and WB.
Old 07-25-2010, 01:52 AM
  #39
ffwturboZ
ffwturboZ's Avatar
Any pics?
Old 07-25-2010, 03:55 AM
  #40
midz350
midz350's Avatar
The one in the upper right.
Sorry, I did that over a year ago and I can't get any new pics.
Quick Reply: Finally!! It can be done..
