clutch pedal hit the floor???
so i was driving and the clutch pedal hit the floor ad got stuck untill i pulled it back up. the clutch will not disengage now. i read an old post about a similar problem saying it might be the slave cylinder? i dont know much about cars myself any input before i take it to the shop would help thanks guys
What's wrong depends on the year.
The '03-'06 has a conventional slave cylinder mounted on the outside of the transmission case. There's a clutch fork and a pivot ball between the slave and the throwout bearing. The pivot ball is prone to breaking off, and that'll cause your problem.
The later versions have a concentric slave cylinder, which is inside the case. It is prone to sticking, but it usually doesn't fail completely in one event like you describe.
Those are the two most likely scenarios, but it could also be the master cylinder or the hydraulic lines.
If you can get under the car, you may see the clutch fork is sticking too far out of the transmission case. That happens when the pivot ball breaks. There was a thread here a several weeks back with a good picture of what that looks like. See post #13 here:
https://my350z.com/forum/engine-and-...h-problem.html
You're looking up, and the front of the car is to the right. That's the left side exhaust manifold at the bottom of the picture.
