Totally Stumped!! Window Issues.. Please Help!!!
Old 08-28-2014, 01:01 PM
stikystikyricky
stikystikyricky's Avatar
Default Totally Stumped!! Window Issues.. Please Help!!!
Hey guys, so this is where I am at.
I have 2003 350z. Ever since I bought it, the passenger window will go down and inch when the door is opened, however it doesnt roll back up. Then it will go down another inch when opened back up.
It didnt bother me too much as I would just roll the window up after then passenger got out. This went on for about a year.
A couple days ago, the window went down, but not back up. Now its all the way down and wont go up. After research I figured it was the motor. I pulled the door panel off and plugged in the new motor. Nothing! Put the old motor back in and Nothing!
I grabbed my multimeter to check to see if power was going to the motor when the button was pressed. For some random reason, when the multimeter is switched to 12v and I checked the power on the first wire(green ish color), the motor moved in the down position for 2 seconds. And the down button would move the motor even with the car off, just not the up button. I grounded that wire and same thing. Motor works in the down position, when the ground is first touched the motor moves for 2 seconds.
What is going on here? So its clearly not the motor.. So I assume its the switch? I called the dealer and they said its 150 for the switch and there are no returns, special order and it will take two weeks to get. I need my car now and I cant have my window down all the time. Could someone please shine some light on this. I have no idea whats going on.
THanks
Old 08-28-2014, 01:14 PM
AdvanZ33
Senior Super Moderator
AdvanZ33's Avatar
Did you try the reset procedure first?
Old 08-28-2014, 01:21 PM
stikystikyricky
The reset procedure requires you to first roll your window up. My window motor doesnt even respond to the up position on the switch
Old 08-28-2014, 04:31 PM
03redlineZ
03redlineZ's Avatar
I had a similar issue but was resolved with a new window motor. Did you try the new motor and window procedure withbit?
Have you considered the button that triggers the window to go down when the door is open may be malfunctioning as a Co problem
Just a thought
Old 08-29-2014, 07:44 AM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
Question
You have tried the new motor using both pass and driver window switches?
Make sure the window lockout switch on driver armrest is not down.
GL
Siqcology
09-18-2019 01:45 PM
pslamp32
02-08-2017 09:07 AM
Boots patrol
Exterior
11-07-2015 12:26 PM
AP350z223
09-08-2015 04:38 PM
Darkspy
09-07-2015 09:09 PM
Quick Reply: Totally Stumped!! Window Issues.. Please Help!!!
