coil packs
Old 02-25-2015, 10:43 PM
Yaustinz33
Yaustinz33's Avatar
Default coil packs
so ive been having this random misfire problem code p0300 and im curious about coil packs which ones could I use on my 03 z? could I use some from new model z's maxima's frontiers etc other cars? I found some pretty decent price on ebay....lol but may people say just use used ones or good companys on ebay for a less expensive route please help! tahnks
Old 02-26-2015, 05:07 AM
travlee
Master
travlee's Avatar
Received 9,049 Likes on 6,515 Posts
try rockautp.com they have them ranging from 27-80 dollars
Old 02-27-2015, 10:12 AM
monztr
monztr's Avatar
Just gonna throw this out there, you already changed plugs right?
Old 03-01-2015, 01:58 PM
Yaustinz33
Yaustinz33's Avatar
yes I did! ngk iridium and I think im going to try to clean MAF and check the connection to coils cause it will act up ill start unplugging and touching things and some times itll run fine
Old 03-03-2015, 02:25 AM
bender
bender's Avatar
If you're looking for stock packs for an 03, they are made by Hitachi. There's 3 or 4 Nissan/Infiniti's from 03-08 that use the same packs. There's quite a bit of aftermarket solutions also.
Old 03-03-2015, 12:41 PM
Yaustinz33
Yaustinz33's Avatar
would I be able to buy say 08 350z coils and use those on my 03?
Old 03-03-2015, 12:45 PM
travlee
Master
travlee's Avatar
i would try to stay in the same year range for the de motor... just my thoughts
Old 03-03-2015, 12:53 PM
bender
bender's Avatar
03-06
Old 03-06-2015, 06:58 AM
monztr
monztr's Avatar
It seems to me if the coils were the coil packs it wouldn't be a random misfire but a constant on whatever cylinder is the issue. Makes me wonder about the CAS?
Old 03-06-2015, 07:40 AM
bender
bender's Avatar
I'd tend to agree. Usually with a bad coil pack, it will lead you to the exact cylinder through an error code (e.g. p0302 Cylinder 2) versus a random misfire code. I'd start by exhausting some other options first (vacuum leak, maf sensor, spark plugs).
Old 03-07-2015, 12:09 PM
Yaustinz33
Yaustinz33's Avatar
true but if its multiple cylinders it would throw p0300 random meaning multiple coil pack
Old 03-09-2015, 01:02 AM
bender
bender's Avatar
No, that's not what it means. If one or more coil packs fail at the exact same time (which I wouldn't count on just yet), you'll usually still get the cylinder number. It doesn't automatically go into random misfire because 2 or more packs go. If it's able to give you the code on 2 or more cylinders, it will.
I'm just curious as to why you're convinced it's a coil pack? Not saying it couldn't be, but what have you ruled out so far? Changing all 6 coil packs at once seems like a bit of overkill if you haven't ruled out the easier options first.
Are there no vacuum leaks? Have you checked your maf sensor? How new are your plugs? If the plugs are due to be changed anytime soon, just change them.
Old 03-09-2015, 07:41 AM
monztr
monztr's Avatar
You can unplug the cop's with the car at idle and see if unplugging one does not cause an idle drop, then swap that cop with a good cylinder if the problem moves it's the COP if not it's not the cop.
Old 03-13-2015, 11:25 PM
bender
bender's Avatar
Just to expand here, stock ignition packs are made by Hanshin. Hanshin is a subsidiary of Hitachi. It's now Hitachi Automotive Systems Hanshin. Hitachi and Hanshin packs are going to be the same.
Hanshin also owns coil factory with Denso. If you get a Hanshin, Hitachi or Denso pack, they'll likely be identical other than the name on the box.
Surfer90291 (07-24-2015)
11-09-2020 10:27 AM
Dr.Paulyy
07-29-2019 07:45 AM
04-04-2016 07:52 AM
derekinthez
South East
09-28-2015 06:35 PM
Quick Reply: coil packs
