Ignition Coils
Old 04-16-2015, 02:45 PM
#1Pussologist
#1Pussologist's Avatar
Default Ignition Coils
I am approaching 90,000 miles and was planning on doing a tune. Today the ignition coil on cylinder 2 failed, should I replace all of the ICs as well as all 6 spark plugs or just the IC on cylinder 2 new with 6 new sparks. What else should I check/replace around this mileage?
Old 04-17-2015, 07:29 AM
rustyschopshop
rustyschopshop's Avatar
Replacing all the plugs would be the best idea with 1 coil. If you want to install a fresh new full set of coils that is up to you. Technically speaking as coils age they get weaker.I had 1 fail last year and just changed the 1 but plan on doing a coil upgrade in the next year or so and replace the full set.
lolwatbro
10-09-2021 04:58 AM
11-09-2020 10:27 AM
04-04-2016 07:52 AM
derekinthez
South East
09-28-2015 06:35 PM
irishguy0224
09-22-2015 06:57 PM
Quick Reply: Ignition Coils
