You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I figured this would be most appreciated here since N/A is looking to maximize performance in every way possible. If this isn't the appropriate section, mods feel free to move.
I started my throttle body project this weekend and took some measurements and pictures. I hope this helps someone as it was surprising to me that our 3.5l v6 uses the same size* throttle body as the 5.6l v8
*the inlet, outlet, and throttle plate are the same size. there is however more meat on the 5.6l if someone were to bore it out. *
I haven't looked into how the signaling is different between the two, if at all... I noticed they each have 6 connections. I assume two are for the electric motor and 4 for the position sensors. While they are oriented differently they both seem to have the same functions and should output the same result except for the possibility that the sensors send different ohms out for a given position.
to adapt the VK56 throttle body to the VQ35 plenum, I was going to get an adapter machined, but easier, get a throttle body spacer and drill holes to match up to the VQ35 plenum.
Pictures:
Click on images for Hi-Res
VK56DE -Left VQ35DE -Right
VK56DE Outlet - ID
VQ35DE Outlet - ID
VQ35DE Diagonal
VK56DE Diagonal
VQ35DE Thickness - OD (This is not solid throughout)
VK56DE Thickness - OD (This is not solid throughout)
Both throttle plates
VK56DE throttle plate
VQ35DE throttle plate
VQ35DE Inlet - ID
VK56DE Inlet - ID
VQ35DE Plenum - ID
This is why you cant take off more than a couple MM from the VQ35DE throttle body
__________________
2006 G LR Coupe - Still in love
in the end, probably nothing even a dyno could pick up but nicely done.
Probably not, but It was done as more of a complimentary mod. It will help when I finish port matching and polishing the upper and lower intakes and the runners. And later when I get my 3" intake going.
__________________
also in regards to the gear ratios, yes they are probably different, just I noticed while the motor gear is smaller on the vk56de the middle wheel is larger. I'm not sure how much it would be off (I'm sure there is some math that can explain) and if the computer could compensate for it. I just got it cheap on ebay so I decided why not? If anything I can throw it back together and resell it for more than I paid.
__________________
Very nice! Do you know of any company that sucessfully ported the TB with no problems of the DBW (drive-by-wire)? I thought I seen Portflow had done it but not 100% sure.
Anyway, the VK56 has 315hp and 400tq, so it is pretty obvious that porting is not necessary to make power gains especially for NA VQ35de gurus...
Proflow was very conservative on their porting jobs. I currently have an old 350evo TB which from what I read, was done by Proflow. It runs well once ECU relearns. Gains? None that I noticed...
__________________
Daytona Blue 350Z (VQ-35DERevup)
Imperial Blue Trailblazer SS (LS2)
Royal Jade Pearl SC300 (2JZ-GE+W58 --> 1JZ-GTE+R154) Stock twins@14psi
the vk56de throttle body is still sitting on my shelf. I never pursued boring it out or converting it because I haven't felt the need yet. It was proven by sash that the TB wasn't the limiting factor on our engines, at least on mild n/a builds.
__________________
