Nitrous Oxide Too soon, jr.
Nitrous Basics Thread, read here if you want nitrous for the first time....
Old 03-04-2007, 01:29 AM
  #41
Nukiz0r
Nukiz0r's Avatar
Oki, so I can gather a few things from this incredibley informative post.
1. UTEC is a great way to go for engine management, as it seems to handle multiple applications - ie Nitrous, FI, N/A. =)
2. I can safely run a 100 shot before I look into doing any internal upgrades. (Which Im sure would be plenty for me.)
3. Im going to have a long drive in the Z from Iowa to get Jeremy to set up my NO system. ;-P
Old 03-06-2007, 11:01 AM
  #42
Tom's_Z
Tom's_Z's Avatar
Just as an aside, has anyone else here run their system using a J&S Safeguard as an alternative to the UTEC? I have one along with the Zex TPS and the Zex window switch, and they all work great together. Beyond that, it also proactively retards timing per cylinder as needed, up to 20'. To me, this makes it better, at least for a nitrous system than the UTEC, since it has that extra safety built in.
Old 03-07-2007, 03:15 AM
  #43
Audible Mayhem
My350z
Audible Mayhem's Avatar
the price on the JnS plus window switch plus tps switch totals to more than the utec. the utec is plug and play so no cutting any wires at all. maybe they will add a progressive control to the switch and make it even better...
my car will be done in less than two weeks
Old 03-07-2007, 04:29 AM
  #44
zman1910
zman1910's Avatar
Very, very nice thread....Thanks Jeremy and everyone that has contributed
If I am at the track, is it possible to turn off the bottle and run stock and then turn on to see the difference in qarter mile times or is nitrous always on?
Also is the install and uninstall pretty easy to do?
How long does it take the bottle heater to work?
Old 03-07-2007, 03:38 PM
  #45
Tom's_Z
Tom's_Z's Avatar
Talking UTEC vs J&S
That's a good point.........I just prefer the extra safety that the J&S will give you by actively pulling timing should it be needed, whereas the UTEC doesn't offer that flexibility. And I didn't mind paying the small difference for it. OF course, I have no intention of going FI, so that was also a factor in my choice. And the other stuff works flawlessly with it.
Old 03-08-2007, 04:57 PM
  #46
Partyboy25
Partyboy25's Avatar
Couldnt find any info on it so....
Was wondering if getting a 3.9 Final Drive would help with a nitrous setup...probly wouldn't spray in the first or second, but what about after that???
Old 03-08-2007, 09:43 PM
  #47
Audible Mayhem
My350z
well sir, the utec actually has a knock control as well, adjustable 0-100 % in every 1000 rpms you use. it is very sensitive and works perfectly. plus lets you take out timing out of your nitrous map for added safety, plus controls your rpm window plus controls the TPS it kicks on with...
all for under 900 dollars if you look at the right place.
plus has a switch to flip between 5 presets maps while you are driving..
Old 03-08-2007, 09:44 PM
  #48
Audible Mayhem
My350z
3.9 setup will make ANY setup faster running through the gears, BUT you will have more traction issues so people chose not to do it, idealy you would want 3.9 with tons of traction on these cars for the fastest times...
Old 03-09-2007, 02:55 AM
  #49
Tom's_Z
Tom's_Z's Avatar
Default Utec
Well then, it really is a nice piece, and it does do one thing I currently can't do that I really need - switch between maps when I turn on the spray. I heard this can be done with a tune with multiple maps that can be switched via the cruise control, but it sounds expensive. So I guess a UTEC is in the cards at some point in the future......Thanks for the info.
Old 03-09-2007, 03:25 AM
  #50
Audible Mayhem
My350z
no problem, thats why i am here, where are some good quarter mile times guys??
Old 03-09-2007, 03:30 AM
  #51
CR8Z1
CR8Z1's Avatar
The pins to tap on the ecu are as follows:
Pin 52 - TPS #1
Pin 60 - cylinder #1 (for RPM signal)
Is this accurate for an 05'; I picked up on a rumor that the pin positions were different on some years.......
Thanks
Old 03-09-2007, 04:46 AM
  #52
jksstar
jksstar's Avatar
coming soon
Old 03-15-2007, 03:16 AM
  #53
Tom's_Z
Tom's_Z's Avatar
Default Zex - fuel Pressure switch?
So I got the 125 pills and wideband 02 sensor for my Zex kit and wanted to know where I should install the 02 sensor. I guess I wanted to know what my a/f ratios are.....what numbers should I be looking for? Assuming my car's setup is running the right numbers, will I then need a tune? Or should I get one anyway?
Old 04-10-2007, 03:46 PM
  #54
driftz
driftz's Avatar
i got nos but think i got ripped how much u get urs 4?
Old 04-27-2007, 10:51 AM
  #55
ridemyjansen
ridemyjansen's Avatar
A question for those with nitrous. Do you guys typically spray through all your gears? Or just the higher ones?ie: 3rd and up?
Old 04-27-2007, 12:59 PM
  #56
Tom's_Z
Tom's_Z's Avatar
I typically spray only in second gear. This minimizes traction issues. I use a Zex Window Switch lockout, and acitvate the nitrous after 3300pm, and switch off at 6200. Activating at 3300 keeps the engine in one piece......
Old 05-02-2007, 06:19 AM
  #57
VicPham
Lifetime Member
VicPham's Avatar
This thread has alot of useful info. All I need to look for now is part #'s for spark plugs and what size gaps I need on the sparks plugs.
I plan on hooking up my zex kit next week. If anybody comes by any info like torque specs for the spark plugs and gap sizes please post them here for future reference. My search function doesnt work at work....
Old 05-02-2007, 09:30 AM
  #58
VicPham
Lifetime Member
VicPham's Avatar
One more thing....would upgrading the fuel injectors be a good thing or bad thing if I were to run 75 shot.
Old 05-02-2007, 11:12 AM
  #59
Tom's_Z
Tom's_Z's Avatar
I'm not sure that's needed for such a small shot. Anyway, I would think your car would run rich whenever the car was off the spray if you did that......
Old 05-02-2007, 06:41 PM
  #60
jksstar
jksstar's Avatar
Originally Posted by jksstar
NGK part # LFR6A-11 (for those of you that don't like to search )
I gapped mine at 35
Quick Reply: Nitrous Basics Thread, read here if you want nitrous for the first time....
