Kinetix plenum shoot out / Stock car / plus more
![Thumbs up](https://my350z.com/forum/images/icons/icon14.gif)
Im sure some of you really want to know what i found out today.
Here is what we did. Test car was a 2003 6spd touring model.
The dyno was a dynojet. All pulls were done in 4th gear. And the ECU was reset in between each mod.
2 pulls each, these are the best results.
The tests were:
Dyno 1 = STOCK
Dyno 2 = Ported Lower Plenum
Dyno 3 = Ported Lower Plenum + JWT intake
Dyno 4 = Ported Lower Plenum + JWT intake + V5 Kinetix Plenum
Dyno 5 = Ported Lower Plenum + JWT intake + V5 Kinetix Plenum + Ported Throttle Body
Dyno 6 = Kinetix SSV + JWT intake + Ported Throttle Body
Dyno 1 STOCK we managed to pull 238HP/224TQ not bad base line
Dyno 2 241HP/228TQ
Dyno 3 244HP/226TQ
Dyno 4 243HP/229TQ
Dyno 5 244HP/229TQ Ported Throttle body did not do much![Smilie](https://my350z.com/forum/images/smilies/smile.gif)
Dyno 6 235HP/221TQ As you see the SSV lost HP over the V5 and alot of TQ![Frown](https://my350z.com/forum/images/smilies/frown.gif)
Here are the dyno graphs
Later
Aceman
The tests were:
Dyno 1 = STOCK
Dyno 2 241HP/228TQ
Dyno 3 244HP/226TQ
Dyno 4 243HP/229TQ
Later
Aceman
Excellent! Im sure people will b!tch and comlain and look for an excuse, but Id trust your write up over a shops anyday. One thing if you could, can you post the other runs for the set-ups as well, that way we can average the 2 runs...nice job! SSV = JUNK
Edit-BTW the #'s are Standard corrected not SAE but thats ok...
Thanks Alberto
Yeah, im sure someone will B!tch, but oh well
it is what it is.
I dont have the print out for the other pulls, just what i posted. And i wanted SAE but i did not notice until we were on the third mod and by then i wanted them all to match.
The SSV did make 4 HP over stock but lost 3 TQ. And when compared to the V5 it lost 2 HP and 8 TQ. I could not believe how much TQ it lost.
Tested my ported TB and it did not do much but did alittle maybe 1HP and 1TQ
Need to install a larger MAF housing and i think it will do better.
Glad we finally got the tests done
I hope everyone appriciates what we did lastnight. We spent $250 on the dyno and 2 hours of our time.
Later
Aceman
Later
Aceman
I would not take anything away from the V5 for a NA car. But the SSV is better suited for a FI car in my opinion.
I have another dyno that i forgot to post lastnight. It shows the STOCK pull and the best pull from the V5 and SSV on the same dyno graph. Will post that up once i get off work today.
Later
Aceman
Later
Aceman
Originally Posted by davidv
Thanks for the important information. Kinetix plenum mods have been losing credibility since the Sport Z magazine tests.
The V5 Kinetix Plenum lost 1 horsepower.
And the SSV lost another 2.
So I suppose that both are for sale.![Wink](https://my350z.com/forum/images/smilies/wink.gif)
It will have to be custom, and you will need engine management of some sort. By making the housing larger your MAF sensor and ECU wont know what to do with the extra air passing through the housing.
later
Aceman
later
Aceman
Originally Posted by tany009
is there anywhere you can get a larger maf housing thats compatible with the stock z one or do you have to go custom and make a bigger one from some other cars maf? i've been intrested in trying this but dont know where to start!!!!
later
Aceman
later
Aceman
Here you go
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/187392-diy-plenum-porting-4.html
Post 193 and 194
Later
Aceman
Post 193 and 194
Later
Aceman
Originally Posted by StarcraftBW
^^^Do you have picture of the ported plenum AceMan? ![Smilie](https://my350z.com/forum/images/smilies/smile.gif)
I thought the ssv was intended for turbo applications anyway. There are many factors that can attribute to your findings. I'm pretty sure with hp numbers exceeding 500+, you would see a significant increase in power over others. Eventhough this was a nice comparison, it does not offer anything that I needed to know.
i am in orlando, and will be getting my car tuned soon by central florida turbo, they are very reputiable. If some one in orlando or near by has a v5 , i have an ssv that i am going to be putting on after the first pull. I have a single turbo kit, and i plan on doing a base run with the reflash, then a retune on the skunk 5/8 spacer , then switching to my ssv and doing a final tune some where around 400hp, but if some one would like to bring a v5 , and help me swap it , ill do a run or 2 on it. I ll be more than happy to post the dyno sheets and results, ill pay for all the dyno time as well.. i think it is great when poeple step up and and put these things to there test.
I had JWT Intake and Tanabe Exhaust prior to my Kinetix V5 install.
I believe prior numbers were around 237whp, after numbers around 242whp, so it made power for me? I believe davidv was on hand that day to see the pull and dyno.
[QUOTE=aceman]I would not take anything away from the V5 for a NA car. But the SSV is better suited for a FI car in my opinion.
+1 With a GOOD tune!
