The real problem with true coilover rear suspension...
Old Aug 19, 2006 | 06:26 AM
twenzel's Avatar
twenzel
Default The real problem with true coilover rear suspension...
I think I may have figured out the reason for all the noise in the rear... I have tried isolating every bit of the rear coilover to find where the noise is coming from. (squeaking, thuds) After many attempts with no solution and even two different coilover systems (buddy club and Stance). I believe the problem to not be with the coilover unit at all.
Instead the problem is with the lower mount of the rear shock. Which is a weak rubber bushing. This bushing was originally intended to only withstand the dampening force of the factory shock absorber where most of the weight is resting on the spring in the OEM location.
But with a true coilover in the rear you are now putting all the weight of the rear plus all the force of shock on this single bushing. I looked at it closer this morning and mine is starting to crack and is no longer doing its job. I believe this is what is making the noise.
Please everyone with true coilover in the rear check and see if yours is wearing pre-maturely. If this is the case, we need to fabricate some spherical bushings for this location.
Attached Thumbnails The real problem with true coilover rear suspension...-rear.jpg
Old Aug 19, 2006 | 07:43 AM
NoLimit's Avatar
NoLimit
good find
Old Aug 19, 2006 | 11:24 AM
ihatethatbobbarker's Avatar
ihatethatbobbarker
checking
Old Aug 19, 2006 | 08:29 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Ohhh...good find bro. I'll look into that one with my shop.
Old Aug 19, 2006 | 08:36 PM
Gsedan35's Avatar
Gsedan35
I may have something to reduce inpact harshness related to the springs. Your rear springs use 2.5" inside diamter springs, right?
I made isolation rings out of a silicone rubber material, greatly helped with my impact harshness issues with pillowball upper mounts. It's the white material you see in the pic below.
Old Aug 19, 2006 | 09:59 PM
ihatethatbobbarker
still havent checked, but ive never worried because they never sounded more squeaky then my previous coilovers.
I have alot of problem with lifting one wheel in the air when going up slopes at an angle like parking lots because my rear shocks dont have much travel.
does it happen to anyone else or is it just the consequences of how ive setup my suspension?
Old Aug 19, 2006 | 10:50 PM
twenzel's Avatar
twenzel
My rear suspension lifts a wheel coming in at angles all the time.
Any one know of any shops that could make some spherical bushings?
Old Aug 20, 2006 | 07:58 AM
NoLimit's Avatar
NoLimit
^ maybe you could ask Alex @ Battle Version.... i'm sure if he knows it is an issue, he would have some made, ... I think getting a polyurethane bushing in there might be better for daily driving...
Or try SPL or possibly SPC. SPL is already making the aluminum rear diff bushings...
Old Aug 20, 2006 | 01:50 PM
ihatethatbobbarker
yeah, ive mines cracked ill be calling him immediately
Old Aug 20, 2006 | 05:55 PM
twenzel's Avatar
twenzel
I emailed SPL parts and Alex at Battleversion. We'll see what they respond with.
Old Aug 20, 2006 | 11:18 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
^ Nice! Keep us posted.
BTW...when you guys go over driveways, do you guys get popping noises from the rear? It varies per driveway but I get several popping noises from the rear when I go up or down a driveway. I don't think it's clunking like what some people have called it but I could be wrong. I get nervous since it sounds like my suspension is going to break off or something. Not sure if it's the coilovers or the fact that I have my sways set at full hard.
Old Aug 21, 2006 | 04:24 AM
twenzel's Avatar
twenzel
Where did you find the silicone material?
Old Aug 21, 2006 | 06:33 AM
NoLimit's Avatar
NoLimit
Is it a creaking/popping sound? You have coilovers? If so, that's probably your springs compressing/turning when at funky angles...
or it may be your sway bar too, ... but that really wouldn't make that much noise...
Old Aug 21, 2006 | 08:28 AM
350Zteve's Avatar
350Zteve
Is there an aftermarket bushing available for this?
Old Aug 21, 2006 | 09:51 AM
twenzel's Avatar
twenzel
Originally Posted by SPL PARTS
We are planning to produce spherical bearing bushings for the rear spindle,
however it will be a few months before we get to them as we are working on
other 350Z products right now.
FYI we are not certain if this is a complete solution for your setup, while
the spherical bearing bushing can take the loads involved, the
spindle/upright is aluminum and the area around the bushing is not as
substantial, relative to other applications such as the Z32 300ZX where the
spindle is also aluminum and the coilover mounts on the spindle from the
factory, the size of the spindle and bushing on the Z32 is much more
substantial.
Even though SPL says the spindle isnt very substantial, Spherical/metal bushings will help with the noise and integrity of the suspension.
Old Aug 21, 2006 | 10:17 AM
ihatethatbobbarker
just the sound of my tire hitting the floor, and Ive ahd a tick tick tick from my axle when my car was stock, but so have alot of people.
i wonder if the one wheeling has caused yours to crack from coming down, is it on both sides?
Old Aug 21, 2006 | 01:07 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Well...it's not the axle clicking noise since I know how that sounds like. It's only in the rears & yes I do have full coilovers (Stance). It's pretty loud & annoying so I'm pretty sure it's not normal. Hmm? I'll probably bring it in to the shop to have them take a look at it this week.
Old Aug 22, 2006 | 04:06 AM
twenzel's Avatar
twenzel
Originally Posted by Alex Pfieffer @ BattleVersion
Hey Tony,
Yeah, I've always looked at the rubber bushing and figured they would go bad. I just didnt know how long it would take before I would start hearing complaints about it. I havent looked into making something to eliminate that bushing yet and I'm not sure when I'll have time. I've been really busy laitly so its something thats going to have to wait till the off season.
Alex
Anyone else interested? I'll start looking into materials to make this part.
Old Aug 22, 2006 | 08:57 AM
Gsedan35's Avatar
Gsedan35
An unlikely source. Home Depot, faucet isle, search the misc repair parts section and you'll find this.
Mark the size you need, start a cut with a razor, finish with scissors. I'm using 2 stacked at the top and one on the bottom.
{edit} my picture hosting site is having some trouble for some reason
Old Aug 22, 2006 | 09:27 AM
NoLimit's Avatar
NoLimit
i think SPL is dead on with their view, ... i think the aluminum bushing Will help, ... but i'd worry how it will affect the upright, ... i mean b/c of the small size of the upright, i could see an aluminum bushing weakening or cracking that 'housing'. That's the reason i was weary of going with true coilovers...
I'm sure there will be a full spindle/upright replacement within the next year...
But for people who need something now, ... I would think you could get a properly sized urethane bushing (which I think would put less stress on the upright) from prothane or senergy suspension ....they list quite a few sizes for their shock mounts/etc on their website(s)... you can probably also get a urethane spring isolator to help with the noise...
just a thought...
