The real problem with true coilover rear suspension...
Old Aug 22, 2006 | 09:39 PM
AlexPfeiffer's Avatar
AlexPfeiffer
You have 3 basic options as a replacement.
First is an aftermarket bushing. That would be the best for most street aplications but would also not last as long.
Second would be a delrin replacement for the bushing, but that would make way more road noise and bind the suspension.
Third would be a mono-ball style bushing replacement that uses a sepherical rod end to replace the bushing. That would allow freedom of movement and last the longest. It would also be the most expencive.
Old Aug 22, 2006 | 10:47 PM
dza00's Avatar
dza00
good find^^
Old Aug 23, 2006 | 04:37 AM
twenzel's Avatar
twenzel
What about a hard poly urethane bushing? Not one of the red soft urethane. And then welding some reinforcing aluminum to the area to strenthen the spindle?
Old Aug 23, 2006 | 05:44 AM
AlexPfeiffer
Most of the red bushings you see are about 80% urethane. The problem with urethane is that the harder you make it, the easier it is to crack.
Old Aug 23, 2006 | 09:29 AM
NoLimit's Avatar
NoLimit
Alex, ... did you have any plans on making a replacement for the spindle/upright??
What about the spherical rod end you mentioned? I'm many people would jump on it since it seems more and more true coilover systems are coming out for the G/Z.
Do you think there is a strength problem with the upright when using the true coilover?
Old Sep 1, 2006 | 05:32 PM
KShep's Avatar
KShep
Subscribing. The Zeals started making some odd noises...hoping it is just the sways.
Old Oct 30, 2006 | 03:29 PM
dewuser's Avatar
dewuser
I have my Stance's on for about 2000 miles. The top bushing on the rear knuckle (Spindle) looks fine on my Z!
Old Oct 30, 2006 | 04:31 PM
dewuser's Avatar
dewuser
Here is a suggestion:
https://my350z.com/forum/showthread....57#post2931057
Old Oct 30, 2006 | 07:59 PM
ihatethatbobbarker's Avatar
ihatethatbobbarker
mine looked fine this weekend, i think ive got about 10,000-15,000 miles on it, cant remember exactly, im leaning towards 15,000.
Old Oct 30, 2006 | 10:41 PM
DMK's Avatar
DMK
Originally Posted by dewuser
Interesting, I might try this when I get mine.
Old Nov 26, 2023 | 11:29 AM
burko's Avatar
burko
Sorry for the insanely old thread revival, but did anything ever come from this? Do any companies offer a fix for this issue?
I am aware that the general consensus is that this isn’t as big of an issue as it is on some BMWs, but if there is even a chance that this is a failure point, I’d like to reinforce it. I will link a few more threads talking about this below:
http://www.the370z.com/brakes-suspension/112451-calling-all-true-coilover-rear-suspension-users.html
https://my350z.com/forum/brakes-and-...ting-area.html
https://my350z.com/forum/brakes-and-suspension/356556-true-coilover-rear-damper-or-not.html
http://www.the370z.com/brakes-suspension/122779-true-coilover-supporting-mods.html
https://www.myg37.com/forums/brakes-and-suspension/285401-long-term-true-coilover.html
JETPILOT
Apr 17, 2019 07:58 PM
SoCali-Z
Aug 2, 2016 06:49 AM
Toby-22
Oct 21, 2009 11:34 AM
TheShaddix
Oct 2, 2007 06:39 PM
dza00
Jul 5, 2006 08:15 AM
