07 Stillen Intake Airbox dyno - IOSPerformance's 07 350z
Old May 24, 2007 | 10:27 AM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
Default 07 Stillen Intake Airbox dyno - IOSPerformance's 07 350z
Our initial shipment of 07 airboxes arrived in from Stillen yesterday afternoon, so we set up some dyno time over at Intense Motorsports to test them out.
First off, we dynoed the car to get the stock baseline numbers, as this will be one of our project cars. Stock numbers were VERY impressive and also very consistent, as you can see in the following graph.
268rwhp @ ~6600-6800rpms
234ft.lbs @ 5100rpms.
Next, we installed the Stillen intakes on the car and ran it again. The installation was very easy and didn't take long at all. The car never left the dyno and I didn't even get dirty during the install. First impression... wow, MUCH deeper intake growl. The sound difference is VERY noticeable and we gained a couple peak hp, with measurable gains across most of the powerband as well. These numbers were very consistent and repeatable, just like with the stock setup.
271rwhp @ ~6800-6900rpms
237ft.lbs @ 5000rpms
Overall I'm happy with the results. We didn't lose power anywhere in the powerband and gained a few horsepower throughout most of the powerband. The intakes sound a lot more aggressive than the stock setup. The stock filters are pretty tiny and with the Stillen boxes there's a lot more filtering area, so you should be able to go longer between filter cleaning/changes. Also, my mpg seems to have increased a bit too. It seems to be around 1.5-2.0 mpg better so far, but I'll update this after a few tanks of gas for more accurate results.
Pros:
-More filtering area (stock filters were surprisingly dirty for only having 2500miles of use)
-More aggressive intake note
-VERY easy installation
-Looks to improve gas mileage as well. (I'll update this once I have more miles on the car too)
Cons:
-Loud at WOT (some may prefer this)
-Cost per hp (due to efficiency of stock design)
I'd like to thank Intense Motorsports for allowing us to use their facilities to dyno the car and test out this intake setup.
Thank you,
Old May 24, 2007 | 10:35 AM
sibble's Avatar
sibble
Great info, thanks for the post!
Guess I should check my air filters lol....
Old May 24, 2007 | 10:37 AM
Advent7's Avatar
Advent7
Old May 24, 2007 | 10:38 AM
sibble's Avatar
sibble
possible to get sound clip?
Old May 24, 2007 | 10:40 AM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
I took a video, but it's 48mb right now. I don't have the proper stuff to shrink the video here at work, but once I get home this evening I'll be able to shrink it down and post it up online. I'll post up a link in this thread.
Old May 24, 2007 | 10:56 AM
97supratt's Avatar
97supratt
Looks good, thanks for the dyno. Pretty expensive per hp though wow.
Old May 24, 2007 | 11:00 AM
Justin@WestCovinaNissan's Avatar
Good lookin out!
Always nice to see dyno numbers.
Old May 24, 2007 | 11:53 AM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
I was wrong. There is a computer here at work that has the software necessary to resize videos.
http://www.InfinitiPartsUSA.com/Justin/402837.mp4 (about 1.6mb)
It was taken with a canon digital camera, so the microphone isn't the greatest, but hey, it's better than nothing...
Thanks,
Old May 24, 2007 | 11:55 AM
Chebosto's Avatar
Chebosto
did nissan ever market that 3 more hp at 60+mph gimmick on the new Zs that they did for the new G Sedan?
did u install the stock after the stillen intake dynos to re-baseline?
Old May 24, 2007 | 11:58 AM
Gooey's Avatar
Gooey
thx for the dyno and clip!!
THE TECH's Avatar
THE TECH
So definitely not worth the price tag.
Old May 24, 2007 | 12:09 PM
97supratt's Avatar
97supratt
Was the ecu reset after the insall? I'm pretty sure the HR motors are efficient when it comes to the intake side of things. Most of the big gains are coming from tp's and exhaust.
Old May 24, 2007 | 12:12 PM
Gooey's Avatar
Gooey
ill mainly get the intakes for the sound it produces
Old May 24, 2007 | 12:13 PM
blasian's Avatar
blasian
+1
I was curious on if the ECU was reset or not. Not that I think it would make a huge difference or anything.
Old May 24, 2007 | 12:16 PM
Mike@IOS's Avatar
Mike@IOS
IOS Performance
We did not re-baseline as the control really didn't change. The swap was done within 1/2 hour and the engine was up to full operating temperature both times. In other words the install was done on the dyno. If you notice the graph of the first 3 runs, the power is very repeatable regardless of temperature. Also the ECU was reset before the initial pull and then again before the intake pull.
As far as worth it? It may not be according to the dyno numbers, however in real world driving conditions I'm sure the difference will increase. The factory airboxes take 100% of the air from in front of the core support while the stillen boxes while isolating engine heat will pull some hot air from the engine on the dyno. Also the sound from outside the car is absolutely awesome.
Old May 24, 2007 | 12:23 PM
blasian's Avatar
blasian
Thanks for the info
Old May 24, 2007 | 12:29 PM
97supratt's Avatar
97supratt
Are the filters stillen uses closed at the front like some k&n filters? Or is it like the JWT filters?
Old May 24, 2007 | 12:32 PM
b00stedjustin's Avatar
b00stedjustin
Originally Posted by blasian
+1
it's a short ram intake setup lol. You can't expect more than 3 hp lol.
Mike@IOS's Avatar
Mike@IOS
IOS Performance
They are K&N's and have the inverted filter cones up front as well as a velocity stack built right into the pipe.
Old May 24, 2007 | 12:52 PM
Justin@IOS's Avatar
Justin@IOS
IOS Performance
here's a few pictures of the intakes installed on the car.
Sorry, forgot to take pictures of the filters and other "parts"... the install went so quickly, we didn't really have time to take pictures... Later this afternoon I'll pull one of the boxes from the warehouse and take pics of the individual components if you'd like.
