2007 VQ35HR Engine Oil Analysis
Old 09-10-2007, 09:34 AM
sibble
sibble's Avatar
Default 2007 VQ35HR Engine Oil Analysis *UPDATED 5/15/08*
Sending in a sample today to Blackstone. Anyone else going to be doing oil tests? I'm very curious to see the results.
The oil used for this first analysis is Royal Purple 5w-30. I already changed the oil and put in Mobil 1 5w-30 and ill be using that for the next 3 oil changes and then doing a test. Any suggestions on another brand to use next time? I'm open for opinions as I am pretty much up in the air at this point on which oil to use.
UPDATED 11/12/08:
<a href="https://my350z.com/forum/members/81090-peak350.html">Peak350</a> - added Royal Purple
Miles on Engine: 17,702
https://my350z.com/forum/6549162-post169.html
UPDATED 5/15/08:
<a href="https://my350z.com/forum/member.php?u=105399">brad568</a> - added break-in analysis
Miles on Engine: 1,350
https://my350z.com/forum/showpost.ph...&postcount=136
UPDATED 4/30/08:
<a href="https://my350z.com/forum/member.php?u=85114">sibble</a> - added German Castrol 0W30
Miles on Engine: 39,774
https://my350z.com/forum/showpost.ph...&postcount=123
UPDATED 2/14/08:
<a href="https://my350z.com/forum/member.php?u=88512">tsabrale</a> - added Amsoil 2000 TSO 0W30
Miles on Engine: 7000mi
https://my350z.com/forum/showpost.ph...6&postcount=81
UPDATED 1/23/08:
<a href="https://my350z.com/forum/member.php?u=85114">sibble</a> - added 2nd mobil 1 5W-30 analysis
Miles on Engine: 31,600
https://my350z.com/forum/showpost.ph...4&postcount=67
UPDATED 12/5/07:
<a href="https://my350z.com/forum/member.php?u=85114">sibble</a> - added castrol syntec 5W-30 w/ lucas oil stabilizer
Miles on Engine: 26,300
https://my350z.com/forum/showpost.ph...0&postcount=52
<a href="https://my350z.com/forum/member.php?u=88512">tsabrale</a> - added amsoil 0W-30
Miles on Engine: 4,673
https://my350z.com/forum/showpost.ph...8&postcount=31
UPDATED 10/26/07:
<a href="https://my350z.com/forum/member.php?u=85114">sibble</a> - added mobil 1 5W-30
Miles on Engine: 21,000
https://my350z.com/forum/showpost.ph...0&postcount=40
UPDATED 9/25/07:
<a href="https://my350z.com/forum/member.php?u=85114">sibble</a> - added royal purple 5w30
Miles on Engine: 16,000
https://my350z.com/forum/showpost.ph...0&postcount=18
Old 09-10-2007, 10:22 AM
tomtom
tomtom's Avatar
try the AMSOIL s2000 0w30
Old 09-10-2007, 01:21 PM
krnnerdboy
krnnerdboy's Avatar
Motul????
Old 09-10-2007, 02:49 PM
singh
_______________
singh's Avatar
I have 1,147 miles on my 07 and I'm going to change the oil at 1,500...I'm going to put Castrol GTX 5w-30 (conventional oil) in. Once I reach 3,000 I guess I'll switch to Castrol Syntec 5w-30....
Old 09-10-2007, 08:20 PM
Marino Z
Know it all
Marino Z's Avatar
I am using motul. It's been 100 miles on motul
Old 09-11-2007, 10:48 PM
itsjiggajames
itsjiggajames's Avatar
based upon resolutes thread, the motul 300v and motul 8100 are actually not that great for Daily driven cars.. at least for the vq35de.. I don't know about the HR until people actually do an oil analysis. I'm running motul 8100 5w30 eco-tech now, but i probally will switch to mobil 0w-40. Last I checked it is still a group IV synthetic, and i've seen many oil analysis come back good for the 0w-40. even on other cars. i use to be on e46fanatics.com, and I gave my e46 0w-40 all day. Ran like a champ..
Old 09-12-2007, 02:24 AM
Tac-M
Tac-M's Avatar
i can see doing an oil analysis on a certain oil, but changing brand every oil change , in my opinion, will not give an accurate results. i believe there will be a to much of an oil "mix" since not all of the oil is drained.
Also, I am sure that the result will differ on a fully broken-in engine. So wait till you are at like 5k, befor doing this “study “
Motul 300v here, and I’ll stick with it. By the time I get to 50k, I’ll be in a new car anyway, so why stress. I could even go dyno oil…. ( but my engine would run like crap and be loud as chit )
Old 09-12-2007, 05:49 AM
sibble
sibble's Avatar
I have 17K on my 07, would you consider that broken in?
And I've run Royal Purple for the past 4 oil changes. I'm going to run mobil 1 for the next three, and then do another test. I guess I should have been more clear on that, "next time"-meaning next time I choose another brand and send in a test.
Old 09-12-2007, 05:54 AM
Tac-M
Tac-M's Avatar
ok ! that clears it up !
Old 09-12-2007, 07:00 AM
drivesolo
drivesolo's Avatar
I've heard that you should run a new car on conventional oil forthe first 2 oil changes / 5-6k mile miles, before switching to full synthetic. Supposedly Synthetic doesn't 'bond' as well as conventional oil to metal parts.
At the same time, I understand that BMW's come w/ Mobil 1 from the factory.
Can anyone help me understand why there is this difference? I'm at about 1400 miles now and I'm looking to change my oil soon.
Old 09-12-2007, 07:15 AM
Tac-M
Tac-M's Avatar
^ not in this thread, please!
Old 09-13-2007, 03:53 PM
tsabrale
ima shirimasen
tsabrale's Avatar
I changed my oil to amsoil 2000 0w30 at 1251mi. I am at 3000 or so now. I plan to change my oil and send in for a analysis at around 4500-5000. I will also have some track miles on the car by then.
Old 09-13-2007, 06:20 PM
singh
_______________
singh's Avatar
^^did the factory oil come out dirty when you changed it at 1,251 miles??? I was gonna wait until I reach 3,000 miles to drain out the factory oil....
Old 09-13-2007, 06:50 PM
sibble
sibble's Avatar
Originally Posted by tsabrale
I changedy oil to amspil two 0w30 at 1251mi. I am at 3000 or so now. I plan to change my oil and send in for a analysis at around 4500-5000. I will also have some track miles on the car by then.
sweet im curious to see how the analysis comes out
hopefully mine should be done soon, not sure how long it takes for results...
Old 09-14-2007, 08:52 PM
tsabrale
ima shirimasen
tsabrale's Avatar
It actually wasn't too bad. Of course the oil is dirty, but like another member on this forum I wanted to switch to synthetic asap. Putting in the Amsoil TSO 2000 0w30 was more piece of mind than anything. Since the oil change i made sure to keep a close eye on the oil level. So far no burning oil issues. Of cours, after the change I have been driving my a as it was meant to be driven. The oil filter I used was k&n's with a filter magnet on it. That will probably affect the analysis a bit but we will see. I plan on sending an oil analysis every oil change on this car. In any case I plan to track this car as much as I can so I will probably change my oil sooner than later.
Old 09-14-2007, 08:55 PM
tsabrale
ima shirimasen
tsabrale's Avatar
yeah I am curious on any vq hr. I know amsoil is great for the regular de and rev up so I want to see how it does with our engines.
Old 09-16-2007, 04:50 AM
Kuruma-san
Kuruma-san's Avatar
im going to try out that royal purp, i can get that stuf for HELLA cheap, got a little over 1500 on my 07
Old 09-25-2007, 05:32 PM
sibble
sibble's Avatar
Default royal purple analysis
well im done using royal purple, hopefully a few more changes with mobil1 will be better.
This is the Royal Purple 5W/30@16k miles oil analysis
Old 09-25-2007, 09:38 PM
Resolute
Resolute's Avatar
Looks a lot better than the same oil in a DE engine does. Interesting that BL uses the DE averages in your report. I wonder if they know the HR is an 80% different engine. The larger journals should help reduce wear numbers of lead and copper over the rediculously hard wearing DE engine. I have seen very few engines chew up an oil like the DE does. At this point would say your break-in metals are out of the system, so this is an accurate report on the oil's performance. I don't expect the M1 5W-30 to be any better, but we'll see.
Thanks for posting the report. If you want to post your next UOA the next oil change, it's fine. Your trends will not be affected by the minor amount of residual from the previous oil. If the M1 is working better, it will show. if it's not, it will show. As an example, Shushiakary switched from Motul 300V to Amsoil TSO and his Amsoil wear results reflected the same results as six other Amsoil TSO UOA's from DE engines. The only time I would run a cleaner or high detergent oil between oil changes to prevent a previous oil from affecting the new blend is if the prior oil was a POE base. Polyolesters don't mix well with PAO's. This is not the case here.
I guess it's about time I made a comparison chart for the HR engine in the Oil Analysis sticky.
Will
Old 09-26-2007, 08:30 AM
raihansdg
raihansdg's Avatar
yo whats with magnesium??? try the amsoil 0w-30 too
Quick Reply: 2007 VQ35HR Engine Oil Analysis
