HR lower IM runner on DE?
Old 02-19-2017, 03:27 PM
Sak350
Sak350's Avatar
Default HR lower IM runner on DE?
Hey guys! I was wondering if anyone knows if the HR lower runners would fit on a de? I have a HR manifold with cable TBs already. I was going to build an adapter but if an hr runner can fit that would be great.
Old 02-21-2017, 06:32 PM
venture210
venture210's Avatar
If I can get my buddy to let me borrow his old lower DE mani, I'll see if it fits and post it up
Old 02-21-2017, 09:24 PM
bealljk
bealljk's Avatar
It may fit, it may not...It my sneaking suspicion that you'll lose efficiency when you go from circular to square intake runners...decreasing your intake flow and decreasing your power.
Old 02-25-2017, 01:29 PM
Sak350
Sak350's Avatar
It would be much easier to install the HR intake manifold though.
Old 02-25-2017, 01:48 PM
bealljk
bealljk's Avatar
how hard is it to install a DE??
Old 02-25-2017, 02:36 PM
Conway_160
Conway_160's Avatar
How would you control the second throttle body, if you put this on a DE?
Old 02-25-2017, 05:49 PM
bealljk
bealljk's Avatar
^ not the plenum...just the intake manifold...(or at least I hope the OP considered this!)
Old 02-26-2017, 05:27 AM
Sak350
Sak350's Avatar
link g4+ and the vipec v88 can control it.
Old 02-26-2017, 07:40 AM
bealljk
bealljk's Avatar
I'm a big fan of Link and I only know a little about vipec ...
I would say get the parts, start a build thread to document the work and give it a go!
Just being a pessimist and devil's advocate - but I think you'll run into problems with the hardware (including the TBs) working with each other and once it all does come together I don't think you'll see significant gains...but please prove me wrong - use me as motivation to get it done!
Old 02-26-2017, 08:29 AM
Conway_160
Conway_160's Avatar
Wouldn't you want to run a HR plenum so the ports all line up. I would imagine the circle ports of the DE wouldn't line up well with the square ports of the HR manifold. Also you could flow a lot more air with two intakes instead of one.
Old 02-26-2017, 08:51 AM
Sak350
Sak350's Avatar
Yes! The point is to run HR intake manifold so the ports line up. I'm going try and source HR lower runners and test fit.
Old 02-26-2017, 08:54 AM
Sak350
Sak350's Avatar
I will run into problems but i'm going to try my best. I will need hr fuel rail and some other parts. I will make a build thread once i get all the parts.
Old 02-26-2017, 10:19 AM
bealljk
bealljk's Avatar
Dont do your best ... do my best
You may be the smartest person in the room ...
pre-subscribed...
Old 02-26-2017, 01:57 PM
Conway_160
Conway_160's Avatar
You're going to have to make a custom intake with 1 throttle body and 1 maf or find a way to run to run two MAFS and two throttle bodys. On a DE harness
Old 02-26-2017, 05:24 PM
Sak350
Sak350's Avatar
The g4+ has a internal map sensor. It replaces the oem ecu and you can turn off the dbw tb control.
Old 02-26-2017, 09:09 PM
bealljk
bealljk's Avatar
G4 is potent...very impressed with their technology
Old 02-27-2017, 06:26 AM
Conway_160
Conway_160's Avatar
Oh never heard of them, good luck with the build
Sak350 (02-27-2017)
Old 02-27-2017, 08:29 AM
Sak350
Sak350's Avatar
I'm impressed as well! Exactly what I was looking for.
Old 02-27-2017, 08:53 AM
bealljk
bealljk's Avatar
sorta feel like I got the short-end of the stick w/my haltech...
Old 02-27-2017, 12:26 PM
Conway_160
Conway_160's Avatar
Whats the diff between haltech and G4+?
