Cams for HR track car with a custom exhaust (LTH & 3.7L in future)
Old 03-07-2017, 02:32 AM
GodISmE
GodISmE's Avatar
Default Cams for HR track car with a custom exhaust (LTH & 3.7L in future)
I have an opportunity to buy and install upgraded cams now but I won't be able to install long tube headers and potentially do 3.7L until probably next season.
I need to replace the oil gallery gaskets now so I'm thinking about replacing the cams while I'm at it. I don't know which ones to get though, e.g. JWT or Tomei, 264 or 272, 10.8 lift? Which ones should I get with my next year's goal in mind and can I install them now with stock headers? Pros, cons?
To complicate things even more, I'm building a custom exhaust next month and I was planning to do decats and a simple 2x2,3'' -> Y design with a stock type muffler at the end. Do I need to change this design if I want to install the cams now and PPE LTH in future?
I would get it all tuned after cams and exhaust. My goal is a NA track car.
Old 03-24-2017, 06:41 AM
GodISmE
GodISmE's Avatar
No opinions? Does it make sense to install something like 280i/272e cams with stock headers and a 2x2,3'' ->Y exhaust for now but with a plan to install LTH in future?
Perhaps I should go with something more mild like 264/264? Or shoud I just leave stock cams for now and only install bigger cams when I do LTH and the car will be a dedicated track car?
Old 03-24-2017, 07:12 AM
venture210
venture210's Avatar
Go with a 2x2.5" into a 3" for fluid mechaincs reasons. Something like 272/272 would probably suit you really well once the LTH are on
Old 04-02-2017, 02:22 PM
Frostydc4
Frostydc4's Avatar
Do you mind tuning the car twice?
Old 04-03-2017, 05:14 PM
GodISmE
GodISmE's Avatar
^shouldn't be a problem.
My exhaust guy is suggesting stock diameter decats going into 2,5" Y and mid pipe for best power gains if staying with <400hp NA.
