UTEC 'Upgrade?'
#81
on
try pulling the cable of those sensors and you shall see the difference in terms of power
those little things do have effect on car even during idle which causes the rough idle of our cars imo
#83
on
a good friend of mine is doing Z utecs now.he told me its pretty easy to set up the parameters for it and what not.if u wanna get in touch with him.heres his site: http://marylandturbosolutions.com/catalog/
#85
on
As I've said before, I have the 350z portion ready, but I'm still working on some other BIG requests, some dating as far back as the first release! Trust me, the wait will be worth it!
-jason
-jason
#86
-jason
-jason
#88
on
Yes, the upcoming version 3.0 will support Zeitronix's ZT-2 WideBand meter. As well as a the TechEdge and PLX Devices meters.
No date is set for the next release yet, but it will be soon, I am still working on upgrades...
-jason
-jason
#89
on
-jason
-jason
#90
03 CS Track 6MT
on
Jason,
Any chance on getting a beta copy of the Z release? I have been trying to get the EVO version to work with my AEM and still no luck. I tried a new cable and verified the AEM serial data stream via Hyperterminal. It seems to work great. The stream is flawless and continuous but when I try with your software it stops logging A/F after about 30 seconds or so. SOmetimes it never even starts.
One thing I am wondering is if you force a specific baud rate or anything? It seems to only work at 9600 baud.
#94
03 CS Track 6MT
on
One other simple mod that would be REALLY nice to have would be the ability to LOAD a Log Map. Right now the software allows you to save the log map but there is no way to reload it and view it in the nice colored 2x2 (rpm x Load) layout.
#95
#96
03 CS Track 6MT
on
well so far I have tried mps_uteclogger, UTI, and was hoping for the UTEC Tuner 2005 from that guy in MD but none of them have panned out. They all look like they have decent functionality but none of them have worked with my AEM UEGO wideband reliably.
I think that the problem with the wideband may be the baud rate. The UTEC wants to work at 19200 baud only and the wideband only wants to work at 9600 baud. So close yet so far!
I wish one of these packages was open source so I could make it work!
#97
on
I don't think the problem is in the software. Everything works perfect on my laptop, and I'm using teh AEM UEGO at 9600 baud. It sounds like you may have some serial port conflicts or something along those lines. Have you tried connecting to the UTEC through hyperterminal on one port and connecting to the AEM through hyperterminal on your other port? They should both run without any problems. If they do have problems you'll know its your laptop, not the software. I haven't had a seconds worth of trouble using the MPS_Utec software. Well, I take that back, the only problems I have is when I dissconect the devices while the logger is still running, it doesn't seem to like that!
#98
03 CS Track 6MT
on
Have you verified if your AEM UEGO works at 19200?
I have checked them independently but not at the same time with two HyperTerminals. That's a good idea though. I will try that later today. Thanks for the suggestion.
#100
on
