Out of curiosity.....
Old Aug 15, 2009 | 08:27 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Default Out of curiosity.....
Can you feel 1 or 2 degrees of timing advance on our cars?
Old Aug 16, 2009 | 03:08 PM
maXmood's Avatar
maXmood
Under Boost!
mind the noob question, but what's "timing" in this matter means? and what would adjusting it do?
Old Aug 16, 2009 | 11:25 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Sorry, i mean ignition timing.
It's not an exact science, but advancing it usually gives more power but also brings you closer to detonation. Retarding your timing usually saps power, but takes you away from detonation and generally keeps the tune more conservative. You generally want to retard timing when you go FI.
I've got my flame suit on now if i'm wrong.
Anyone have any answers to the first question?
Old Aug 17, 2009 | 12:00 AM
maXmood's Avatar
maXmood
Under Boost!
thnx for explaining it...
from what i've read while doing a search for an answer to your question, it seems that some ppl do feel the difference, but others don't.
it mainly depends on the amount of power that u squeezed outta the engine. if you maxed it, the timing won't give u a difference, and it was advice to set it back to zero.
hope ^that helps a bit.
and i'm putting my flame suit now
Old Aug 18, 2009 | 12:06 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
From my experience, the oem tune on a Z is already very near max best timing. This means that gains from adding timing would be negligible to non-existant. This remains true for most mild bolt on modifications, and more extreme modifications could require advancing or retarding timing to make best power.
Old Aug 18, 2009 | 12:43 PM
Rafa's Avatar
Rafa
ponle un twin turbo y ya esta tio, uno no siente tanta diferencia con el ECU del coche reprogramado..........
Old Aug 18, 2009 | 01:14 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Le voy a montar un compressor HKS el ano que viene, pero por ahora le estoy haciendo todo lo que pueda NA.
Old Aug 18, 2009 | 01:27 PM
Dynosty's Avatar
Dynosty
English?
The best choice for NA tuning is on a dyno. Off the shelf mail order tunes can help, but a dyno tune will get the most out of it.
Old Aug 18, 2009 | 01:30 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Yeah i'm going to be getting the cypher data logger once i get all my parts on, and get a few e-tunes done. (with the reflash obviously)
Dyno's around here are seriously lacking!
Old Aug 21, 2009 | 02:25 PM
JmNismo's Avatar
JmNismo
i went to a Dallas meet and a friend was walking around with his laptop with cipher and he said he could bump up my timing 2 degrees if i wanted ... so i went ahead and did it ... i noticed a nice lil difference on the bottom end up to about 5500rpms but not much after that ... so i decided to take it to a dyno to see where my AFR's were, and it was way too lean (mid 14's) at WOT passed 5000rpms, which causes the ECU to actually pull timing to stop detonating .. and now i'm stuck back in Oklahoma with no way to reset my timing :-( lol
i have i/h/e so I'm sure i was already running a lil lean so that just sent it over the top lol
does anyone know if resetting your ECU will return it back to stock timing ? even after cipher bumped it up 2 degrees ??
Old Aug 21, 2009 | 02:27 PM
JmNismo's Avatar
JmNismo
but to answer your question yes you will feel a little difference if your not already running a tad bit lean and your ECU doesn't pull timing lol
Old Aug 21, 2009 | 02:56 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
And yet some people swear the difference is over the top when you advance it 2 degrees via the cipher - they even list it as a 'mod'. The difference down low can be felt, but it's not worth the price of admission, especially since that is where you spend all your part throttle time (which is where the bad stuff tends to happen).
OP - the car will tell you where it wants to be as far as timing via datalogs on a dyno. Timing and fuel changes go hand in hand
Old Aug 21, 2009 | 02:58 PM
Z1 Performance
Former Sponsor
resetting the ecu will not help you...you need to have someone with the cipher set the timing back to where it was
Old Aug 22, 2009 | 05:11 AM
JmNismo's Avatar
JmNismo
thats what i figured ... can nissan do it ??
Old Aug 22, 2009 | 06:31 AM
Z1 Performance
Former Sponsor
yes
Old Aug 22, 2009 | 11:35 AM
j.arnaldo's Avatar
j.arnaldo
Bottomline: Stick with factory preset ignition timing; that's the Electronic Control Unit is there for, dude.
