Uprev datalogging parameters
Old Sep 16, 2009 | 10:29 AM
maXmood's Avatar
maXmood
Under Boost!
Default Uprev datalogging parameters
i just received it couple of days ago.
i've ran couple of 0-60 on its current state (Stillen intake, plenum spacer, berk hfc, borla exhaust) and datalogged that with the default parameters.
today i reset the learned fuel settings and had couple of 0-60 runs. and just now, i flashed the car and did couple of runs too.
1- the parameters (names/terms) that shows on the cipher are different than what's adviced by in the PDF for etune purpose. i've selected what's obvious, but there are couple of things that i couldn't find or translate in cipher. can anyone (who has done it) help me out plz?
2- i've noticed the runs i've done before the flash were responsive with good pulls. but i've also noticed the AFR is better than it used to (it was lean before). can i remove the flash that i've just done while Uprev works on my etune?
Old Sep 17, 2009 | 04:23 AM
maXmood's Avatar
maXmood
Under Boost!
Anyone??
Old Sep 17, 2009 | 04:30 AM
cdoxp800's Avatar
cdoxp800
Just switch to your stock map if you have one till they get you a new e-tune.
Old Sep 17, 2009 | 05:38 AM
maXmood's Avatar
maXmood
Under Boost!
i didn't ask for a stock map..
Old Nov 6, 2009 | 01:30 AM
maXmood's Avatar
maXmood
Under Boost!
i'm getting free time now to start messing around with tuning again..
i just need the exact parameters that i have to select when taking runs.. anyone care to help?
Thanks
Old Dec 2, 2009 | 05:02 AM
maXmood's Avatar
maXmood
Under Boost!
finally did it!!! just hope i've done it right.
sent the logs to Uprev.. how long does it usually takes to get the etune?
should i notice a difference between the base tune i got from them and the etune i'll be getting?
Thanks
Old Dec 20, 2009 | 09:52 PM
maXmood's Avatar
maXmood
Under Boost!
nothing from uprev yet...
does it really take that long for an etune?
Old Dec 20, 2009 | 10:11 PM
SniperHunter's Avatar
SniperHunter
Unfortunately, yes. Admittedly, after 10 days I started emailing them for an update. On the 15th day, I got it. You're on your 17 day now. I'd call or email them.
Old Dec 21, 2009 | 02:57 AM
maXmood's Avatar
maXmood
Under Boost!
ow..! they shouldn't advertise the return time as in 2 weeks then!
they didn't even reply on my email confirming receiving the logs.
i'll email them again and hope for a reply.
Old Dec 22, 2009 | 12:03 PM
AznSky's Avatar
AznSky
subscribing for results since I'm looking into Osiris next year.
Will the etune adjust your AFR to make it safer as well?
Old Dec 22, 2009 | 12:08 PM
maXmood's Avatar
maXmood
Under Boost!
^^yea, the base map they sent me had the AFR adjusted... which really helped alot, cuz my car was running lean already.
i'm waiting on a reply from them.. if i don't get a reply before receiving my supercharger kit, i'm gonna post the osiris for sale..
Old Dec 22, 2009 | 01:39 PM
gabez33's Avatar
gabez33
fyi...jared is on vacation last i heard..so Idk
Old Dec 28, 2009 | 03:35 AM
maXmood's Avatar
maXmood
Under Boost!
almost a month, no reply....................................................... ..
are they just 2 blocks running the show?
Old Dec 28, 2009 | 04:33 AM
cdoxp800's Avatar
cdoxp800
This information is not that hard to find. These are the Parameters I used over a year ago.
Good luck.
What parameters should be logged for AFR eTuning?
Old Dec 28, 2009 | 04:37 AM
maXmood's Avatar
maXmood
Under Boost!
Good luck.
thanks bro, i was able to set the parameters, datalogged and sent to Uprev (see couple of posts above).. it's just that i haven't received my etune yet!
Old Dec 28, 2009 | 04:41 AM
cdoxp800's Avatar
cdoxp800
I must have read right over it. It's to early in the morning. LOL. My first e-tune took a while, a long while. Have you e-mailed Jared?
Old Dec 28, 2009 | 01:52 PM
maXmood's Avatar
maXmood
Under Boost!
haha.. i thought u did..
about the etune, i've sent the email to etune@uprev.com (as instructed).. and now i lost all my emails after a corrupted harddrive.
Old Dec 30, 2009 | 01:21 PM
maXmood's Avatar
maXmood
Under Boost!
just sent another email to etune@uprev and jared@uprev
3 more days and it will be 1 month since i've sent the logs!
just hope i get a reply!!!!!!!
Old Dec 30, 2009 | 03:55 PM
AznSky's Avatar
AznSky
I wonder if it's due to the holidays? Hopefully u get a reply soon. I'll be looking to do my tune next spring and I hope I don't have to wait this long
Old Jan 6, 2010 | 01:23 PM
maXmood's Avatar
maXmood
Under Boost!
etune received... haven't flashed it yet, but will do soon and revert back with an update.
