::NISMO Wheels Thread::
#1762
I've Googled this to death.
Does anyone know the offsets for the 2015 NISMO 370Z wheels?
I want to pick up a set for my 350Z, and based on what I've read about other NISMO wheels, the rear wheels should fit without spacers, but the front is where I'll need them.
On another note, I've noticed that most members agree that 350Zs require 20mm spacers up front for other 370 NISMO wheels, yet others use smaller spacers or none at all. Others claim that fender rolling for the rear is necessary. What's the deal here?
I personally don't like the 2015 NISMO wheels since they look like left over 370z accessory wheels and will most likely be expensive to find.
Looking good Steve, I thought I took a pic of your wheels but I can't seem to find it
#1763
I agree Waiz. Personally I like the original Nismo 370Z wheels like I had on my 370Z (and my 350Z for a short while) much better. Those wheels are very unique and they fit the 370Z so well. Plus they don't look bad on the 350Z either. The new Nismo wheels look too much like the OEM 18" wheels that came on the 370Z convertible.
#1767
Bulletproof was taking orders for the R34 spec a few years ago but no one pulled the trigger
If they were 19's I would have considered a set in a more aggressive spec than what I am running but I'm good with mine
#1770
on
Update to my earlier post!
The need for front spacers (at least for these wheels) is confirmed. Without spacers, they'd rub against the suspension knuckles. 5mm Project Kics ones easily solved that problem. The rears bolted on with no problems.
#1776
Those Nismo wheels look really nice on the roadster!
#1778
Best I can determine the lug nuts that originally came with the Nismo LMGT4s are no longer available from Nissan. Anyone have some laying around. I need one to replace a lug nut that was cross threaded.
I really don't want to have to purchase an entire set of lug nuts so that they will all match when all I need is one. I am temporarily using a sliver lug nut that doesn't at all go with the black Nismo ones.
