Rota P45R's Thread
Old 12-27-2006, 05:57 AM
bigphil
bigphil's Avatar
Old 12-27-2006, 06:34 AM
kbomb
kbomb's Avatar
wow..beautiful car.
Old 12-27-2006, 10:55 AM
DRFTER_Z
DRFTER_Z's Avatar
I cant seem to get enough of your car bigphil..... nicely done those are 18s right?
Old 12-27-2006, 11:33 AM
solidsnake
solidsnake's Avatar
Did you cut vents in the bumper?
Old 12-28-2006, 08:47 AM
bigphil
bigphil's Avatar
Yes they are 18's
The cut outs in the bumper are as a result of removing the headlamp washers which are standard on UK cars, always hated them so removed and made the cut outs bigger and fitted ducting behind to feed cold air to the brakes.
Old 12-29-2006, 08:19 AM
WalkerT
Professional
WalkerT's Avatar
rota p45r - hyper black
18x9.5
25+ offset
285/255 35 18 T1R
Eibach pro kit
Old 12-29-2006, 10:17 AM
Hybrid_Det
Hybrid_Det's Avatar
All I need to know is where to buy these wheels? Anybody know the actual weight?
Old 12-29-2006, 10:27 AM
G1s Z
G1s Z's Avatar
about 22lbs
http://www.subydude.com/osc/index.ph...768e19f4655c4e
They are around the middle of the section, u can contact him thru the forums too, i think his name is just subydude.
Old 12-29-2006, 11:16 AM
solidsnake
solidsnake's Avatar
255's look good up front. I decided on 275 front and 295 rear. you guys think thats overkill?
Old 12-29-2006, 02:27 PM
Ep3
Ep3's Avatar
no i have 295/265
Old 12-29-2006, 09:05 PM
Nihilation
Nihilation's Avatar
If your fitting on tires that bulge in the least amount you're not doing any good- just adding more weight and additional slop in steering response. Ideally you want a tire that has an ever so slight inward stretch. Straight flush with the lip of the wheel at most.
For a 10.5" wheel I'd run a 275 or 285...
For a 9.5" wheel I'd run a 255 or 265 but no larger.
For an 8.5" wheel I'd run a 235 or 245 but no larger.
Sure you can run a 295 on a 9.5" wheel and while it may look cool to some people, it's gonna bulge resulting in sloppy handling, weigh a good bit more and cost more than a proper fitting tire. Run a stickier compound if you want more traction. Not trying to burst any bubbles, I'm just saying how it is.
Old 12-29-2006, 09:13 PM
Hybrid_Det
Hybrid_Det's Avatar
I assume the center caps have no fitment issues either?
Old 12-29-2006, 09:48 PM
USANA Z
USANA Z's Avatar
anyone have pics of some royal cosmic blue ones on a Z? they only make them in a +30 offset!!
Old 12-29-2006, 10:09 PM
ctwentytwo
ctwentytwo's Avatar
Wow! Everything clicked here! Awesome lighting in this pic. Corners are soft, and vingetting, but damn! I wonder what lens was used on his D70. See it was taken at 27mm.
Old 03-21-2007, 07:38 AM
nothingremains
nothingremains's Avatar
anymore pics? how much did the set run you guys?
Old 03-21-2007, 08:20 AM
Elohite
Elohite's Avatar
some of mine:
Old 03-21-2007, 08:23 AM
GolfinZ
GolfinZ's Avatar
Old 03-21-2007, 08:27 AM
  #38
350Z_LEE
350Z_LEE's Avatar
Old 03-21-2007, 12:04 PM
  #39
azula
azula's Avatar
these rims are growing on me
Old 03-24-2007, 12:04 PM
  #40
BingPWR
BingPWR's Avatar
I noticed that some sets have the concave spokes in the front, but some sets don't. How do you get the concavity of wheels in both the front and back?
Quick Reply: Rota P45R's Thread
