XXR Wheels Thread
#2081
on
The rims i've looked at are 18 x 8.5 front and 18 x 10 back and the factory offset I found are 18 x 8 and 18 x 8.5 and I am worried the rims won't fit with the brembo brakes
#2084
Post a link to what wheels you are looking at
#2086
http://www.nlmotoring.com/XXR-521-Wh...p/52180142.htm Just order 4 of these and you may need to use a rear spacer depending on the look you want
#2088
Do you know that they make many different size spacers ? I have 5mm, 10mm and 20mm in my garage. It also depends on you definition of fitting. I would probably run no spacer up front and 15mm in the rear if it were mine.
#2090
You won't get much dish out of the xxr 521s, the 006 model will have more of a lip even then it won't look anything like what flush crowd runs. If that's the look you're going for.
https://my350z.com/forum/wheels-and-...s-welcome.html
1178 pages of aggressive wheels, mostly with dish/deep lip.
#2096
Interesting... Neva seen those before. Either that I just neva noticed the secondary lip and for around $1500 I would check out VR wheels and see what they had. Using XXR for wheels and good new tires would be like $1200 tops
#2098
on
Does anyone here know if the xxr 526 in 18s will clear factory brembo brakes? I've read like 65 pages and am done reading lol
I already have them fyi
Also, anyone know if the varrstoen es2 in +38 will look odd ?
#2100
Dont know man. Try them out. I have 06 brakes and 18x10.5 +20 526, fit great with no spacers. I know i can put a massive spacer in the rear. So the rear WILL clear. If you got the 9" wide fronts you can put a massive spacer there aswell. So it CAN also clear.
