G37 wheels on a 350Z?
Old 01-20-2014, 10:41 AM
KingBaby
Hardest Setting
KingBaby's Avatar
To achieve what look? What ride height are you at?
I am going to guess that since it's OEM wheels it's +30...so it's really on what look you wanrt to determine what size spacer
Old 01-20-2014, 11:07 AM
RedScytheZ
RedScytheZ's Avatar
This sounds like a figure it out for me thread...
Old 01-22-2014, 01:48 PM
Boaz350
Boaz350's Avatar
Ive had suggestions to go with wheel adapters but the issue im running into is that they are too large im thinking about a 20-25mm spacer for my rear and a 10mm for the front
the only issue i have with spacers is i dont want any vibrations which is why i was suggested to go with adapters but it seems like they dont make any that will fit correctly so i was hoping someone here has done this before to make their g37s wheels flush with the wheel wells
Old 01-22-2014, 02:56 PM
KornerCarver
KornerCarver's Avatar
Here are the specs on the 19" G-36 wheels made by Enkei.
Sport
Front: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
If these specs are correct for the wheels you are wanting to by, you will need 25mm spacers to get them to look decent. You probably need larger spacers but I would not suggest going larger than 25mm.
Old 01-22-2014, 03:06 PM
07maximan
07maximan's Avatar
Wrong wheels....keep shopping.
Old 01-23-2014, 07:52 PM
Waiz
Waiz's Avatar
Originally Posted by Boaz350
im trying to figure out whos done this before and know what wheel spacers to go with?
Search is your friend...
There are plenty examples in this thread that your thread has been merged into
Old 12-20-2014, 01:49 PM
Vanel
Vanel's Avatar
Here you go...
Old 12-20-2014, 01:54 PM
Vanel
Vanel's Avatar
Clean as ****...
Old 12-20-2014, 02:38 PM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
meh, its alright
Old 12-20-2014, 05:31 PM
mr. sparco
mr. sparco's Avatar
Not light, not the right specs, looks okay at best.
Old 02-08-2017, 04:23 PM
NV Vo
NV Vo's Avatar
Default 370z. Wheels
Hi. Jcope ,, I like those Infiniti wheels,, and I do have the z wheels, wanna trade
Old 02-08-2017, 04:27 PM
NV Vo
NV Vo's Avatar
Default 370Z
Originally Posted by Jcope
Hi everyone I found a good deal locally on craigslist for some nice g37 wheels. I can't seem to find a picture of them on a 350z so I was wondering if anyone has them or has a picture on a 350.
[img][/img]
Hi. text me 4045104371, I have the 370Z wheels. I would like to trade ur Infiniti wheels.. let work it out
Old 02-08-2017, 04:42 PM
travlee
Master
travlee's Avatar
you do realize this post is 4.5 years old, and the OP hasn't logged in going on 3.....way to go noob
Old 02-08-2017, 04:46 PM
350Z/370Z Tech Moderator
MicVelo's Avatar
Received 3,255 Likes on 2,316 Posts
EDIT: OUCH, fell victim to the Noob Errata Syndrome.... didn't EVEN see the date!!! DOY DOY DOY DOY DOY. Ah well, even perfect people make mistakes once every ten years or so.
All depends on what year G37 wheels they are. The ones in this thread appear to be the 19" versions. However, there are/were some variations in size and offset. In any case, they're close to the same as 370Z front wheels - that is, high +40mm offsets (+45 to +47 depending on width). You'll want 20mm spacers to make them fit the 350Z correctly.
Case in point: https://my350z.com/forum/wheels-and-...t-novices.html (Specific to fitting Z34 wheels to Z33.)
If you're trying to flush them, you'll likely need 25mm spacers. I run 20mm on my front 19x9 Z34 wheels (see thread above). Not flush but I don't like spacers to begin with (but use them on the front to fit my bitchin' wheels )and that extra 5mm (to me) is pushing the line IMO.
Old 02-08-2017, 04:48 PM
travlee
Master
travlee's Avatar
mic......come one man. look at the date of the post you responded to and the last time he logged in. smh
Old 02-08-2017, 04:53 PM
MicVelo's Avatar
Yeah, yeah, yeah, see the EDIT in my post.
But the Scotch is wonderful.
Old 02-08-2017, 05:00 PM
travlee
Master
travlee's Avatar
did you try that rum i like yet?
Old 02-08-2017, 07:01 PM
  #38
MicVelo's Avatar
Not yet. Trips to the BevMo are few and far between. Despite the fact it's almost right next door to The 350Z Cafe which we frequent with regularity. PM me the name again, please.
Old 02-11-2017, 06:06 PM
  #39
Just_my_car
Just_my_car's Avatar
I absolutely hated the look of g rims on a z. I had to because my oem fronts were cracked. But to each their own. In the picture the front has a 25mm spacer
RiujinZero
04-16-2021 11:31 AM
JjL
East Canada
06-12-2019 03:04 AM
davidm350
10-31-2015 02:28 PM
hardkicks
09-20-2015 12:28 PM
VQA33
Wheels Tires
09-08-2015 08:30 PM
Quick Reply: G37 wheels on a 350Z?
