PSA: When asking "will this rub"....
#161
on
They are staggard offset... 19x10.5 offsets +27 front +16 rear.. current tires 255/35..
I had them on a stanced rx8. So i dont think it would be too much of a hassle to get these on the g35.. you can see other pics on instagram @illestcarmedia
#163
on
Oh, if thats what factory is .. i can definitely fit these ... the stock rx8 size is 18x8 +50... i had to do a little bit of modding to the rear quarters but not alot so they sould fit fine ... the fronts fit flawlessly on the 8 no mod needed...
#165
on
For sure... im currently getting a new engine or rebuilding the engine.. soon as thats over ill be putting them on... the car is clean though.. cant wait to start modding it .. nothing outragous... just clean.. wheels, suspention, exhaust.. thats what im shooting for.
#166
The fronts won't fit, you will need a spacer to clear the spindle. Most likely 10mm will be needed
#167
on
The spindle? Are you referring to the upper a arm, or the rotors? Ive been getting a few mixed answers.. a few have confirmed fitment, a clp have said some mods will be needed... so i guess i might just have to do a test fit and see
#169
Right now my car is sitting on 18x10.5 +15 or +20 depending on the wheels I mount and a set if 285/35-18 up front
#170
on
A 19x10.5 will start to fit at about +20 on the upper part of the spindle, you know that part that the upper arm bolts to. The barrel is what will rub, you can try a 5 mm spacer , but will most likely need a 10.
Ok ... im trying to figure out all the stuff needed ro make these wheels fit.. from what i understandon the suspention 101 thread, in addition to the coilovers, i will need new upper control arms in the front, camber arms and toe arms in the rear or toe bolts... and i guess 5-10mm spacers in the front.. does that sound about right? Trying to gather all the info so i can get prices on all the stuff ... anyone know aprox. The price of all the parts needed to lower the car? Im hoping its not going to be more than 2k
#171
I hope this is the right forum for this question. I just got a set of used 19" volk gts's, 10.5 all the way around. The offset in the rear is fine, but the offset on the front are +30. I saw them on a z before I bought them and the guy had a 20mm spacer which made them stick out too far from the wheel well for my taste. My question is, what is the smallest spacer I can use to clear brembos and what tire size would you recommend to reduce rubbing? Thank you in advance.
I am running at stock height at the moment. I'm shopping for spacers right now and would appreciate some help figuring out the correct thickness.
Last edited by Wonunder; 08-05-2015 at 03:44 AM. Reason: Left out ride height info
#172
on
#173
Hey guys,
I was wondering if these wheels will fit on a 350z without rolled or pulled fenders. The specs are:
18x10, offset is -15 (FR)
18x10 rear is 0 (O disk).
tires are 225/40 front and 235/40 rear
Will they rub or poke out to much? Do I have to add stupid amounts of camber? The z has a basic coilover setup with camber plates Currently at stock height but I plan on lowering it for a flush look in the future. Help will be greatly appreciated!
#174
Wheel fitment question
Alright so I have a set of wheels I want to put on my 2006 350z.
the Wheels are 18x10 +25. with a 5x120 bolt pattern.
if you must know, they are APEX ARC-8 wheels.
The thinnest 5x114.3 -> 5x120 adapter i could find was an inch think.
which would set the fitment too 18x10 +0.
I am on coilovers, will they fit all the way around is my main question, will I need a pull/roll?
Is there any other way that i could fix my pattern issue? Opinions, Thank You!
#175
Option two is roll all around and pull rear depending on tire size. If u plan on stretching well i have no knowledge on that.
#176
With +0 offset, you definitely need a stretch on your tires at the least. Not sure if thats the look your going for. Also, +1 to the wheels with the right lug pattern note. If you decide to go the route you intend with spacers, make sure they are hub centric
#177
General & DIY Moderator
Welcome- you painted yourself into a corner with the bolt pattern on those wheels. Best solution is sell them to a BMW owner and buy another set with the correct offset and bolt pattern. Using an adaptor will compromise the performance of your Z IMHO.
