Winter storage
Old Aug 10, 2003 | 11:29 AM
cory's Avatar
cory
Default Winter storage
I just picked up the new Roadster and the dealer didn't know squat for details on winter storage. Any tips or must do's...stabilizer, oil changes etc... Thanks.
Old Aug 10, 2003 | 11:39 AM
wren57's Avatar
wren57
drain all the gasoline out of the tank and change the engine oil before you crank it up again. thats all I would do, im sure others would do more...
Old Aug 10, 2003 | 12:43 PM
zand02max's Avatar
zand02max
Draing the gas is not necessary, all you need to do is make sure its full and put some stabalizer in there. I stored my previous car, 02 Maxima like that for 6 months. Just make sure you change the oil before and after. One last thing, ensure you take the battery out while in storage. I have had no problems with mine. Just my .02
Old Oct 11, 2004 | 08:52 AM
onii's Avatar
onii
old thread, but it's that time of year again. the garage space at my apartment leaks a little bit when it rains... is that going to be a problem for the car cover? also...is the car cover going to do bad stuff once it gets really cold? (moisture...sticing to car..ripping off paint)..
worried..
Old Oct 11, 2004 | 08:55 AM
zand02max's Avatar
zand02max
worried..
No problem, that cover is awesome for repelling water.
Old Oct 12, 2004 | 02:04 PM
JKM's Avatar
JKM
fill with gas and fuel stabilizer. I worked on boats for years and this is what we did for winter storage and long-term dry-dock. You should also disconnect the batteries. If you're storing it on a concrete floor you may want to lay something underneath the car to act as a vapor barrier againts the concrete.
Old Oct 12, 2004 | 02:08 PM
qwsxz's Avatar
qwsxz
Unhappy
This is a sad thread.
That is all.
Warm weather come soon!
Old Oct 12, 2004 | 02:10 PM
zand02max's Avatar
zand02max
Some folks say not to use fuel stabalizer in the Z.
Not sure though.
Old Oct 12, 2004 | 02:11 PM
onii's Avatar
onii
i actually have a calicar cover, and not the outdoor one...can i drape something over this cover? maybe i should fix my apartment's garage...argh
Old Oct 12, 2004 | 02:13 PM
Dissolved's Avatar
Dissolved
Put a comforter (sp?) over the car, then put on the cover (if you have enough room). This is for indoor.
For outdoor, buy a tarp and put it over your regular cover. Note that some car covers can sometimes fade the corner bumpers of cars as well. Just take note.
I'd start it up and let it get to full operating temperature at least once a week. We have z32tt's with 20k on the odo ('91 models at that) and we know for a fact letting cars sit is BAD.
Old Oct 12, 2004 | 02:24 PM
onii's Avatar
onii
i think im gonna go for the tarp. and some carpet under the tires. should i swap my stock tires back for storage, or does it not matter? just wanna make sur ei get everything
1) cover + tarp
2) carpet under tires
3) disconnect battery
4) oil change
5) battery maintainer
anythin else? stock tires? i have 5zigens on there...
Old Oct 12, 2004 | 02:25 PM
zand02max's Avatar
zand02max
Don't foget to have fresh oil and a full tank of gas.
I did the same thing and started my Z every two weeks letting it warm up for 5-10 minutes. I connected the battery to a battery maintainer and placed carpet under all four tires. Worked like a charm.
Old Oct 12, 2004 | 02:28 PM
onii's Avatar
onii
how much is a battery maintainer and where can i get one?
Old Oct 12, 2004 | 02:30 PM
Dissolved's Avatar
Dissolved
Yep Zand02max is on top of this
You won't need much more, you're list looks good
Google for the battery maintainer. i've never used one. Then again, I have a charger...
Old Oct 12, 2004 | 02:34 PM
zand02max's Avatar
zand02max
[QUOTE]Originally posted by onii
how much is a battery maintainer and where can i get one? [/QUOTE
Bought mine @ Pep Boys. $60.00, you can find them lower though, I didn't feel like searching though, GL!
onii's Avatar
onii
likethis? http://www.global-merchants.com/home/batsvr.htm
Old Oct 12, 2004 | 02:36 PM
zand02max's Avatar
zand02max
I would buy a maintainer that connects to 110V and connects directly to to your battery terminals.
Old Oct 12, 2004 | 02:38 PM
zand02max's Avatar
zand02max
http://www.batterymart.com/battery/maintainers.html
this is the one I have, works great.
Old Oct 12, 2004 | 02:39 PM
Dissolved's Avatar
Dissolved
eh. One more important thing. Consider buying one of those things to throw inside the car (cant remember the name). You need one because moisture can build up and start causing a nasty smell in the car. I've always cracked my windows a bit in the garage. But if you're storing outside, I know this isnt feasible. I cant remember the name of the thing, anyone?
Also, how long is your car going to be in storage? Notice you have aftermarket wheels. I would put the car on jack stands and bring the tires/wheels in (also prevents flat spots from forming in tires)
Old Oct 12, 2004 | 02:43 PM
onii's Avatar
onii
well, it's going to be in a garage, but it gets cold here, and the damn garage leaks a little bit. i guess i'll put the stock wheels back on.
somethin inside car for moisture???
