Fueling Problem?
Old Nov 2, 2002 | 08:29 AM
Imprezzzzza's Avatar
Imprezzzzza
Default Fueling Problem?
I recently purchased a 350Z Track Model, I noticed while fueling it, it always clicks off at 7 gallons. The next time I went to fuel it, it overflowed and did not shut off. The last time I filled it up it stoped at 7 again. The problem with this is, is when it clicks off and I try to put more gas in it, it keeps clicking off. It has caused me to go to other gas stations... at those gas stations I can fill up just fine. Has anyone else experienced this problem with there Z?
Thanks in Advance
- Vincent
Old Nov 2, 2002 | 08:31 AM
ares's Avatar
ares
Veteran
ummm sounds like its the gas stations problem... often times I find this problem can be fixed by holding the nozzle out a little bit to keep the fuel from spashing back up and clicking off. but if its fixed by going to another gas station, I think thats smart.
I personally like BP with amaco(sp?) gas. but Im not that picky.
Old Nov 2, 2002 | 09:27 AM
hoglecl's Avatar
hoglecl
Yes I have had the same problem. Different pumps seems to help as does turning the nozel to a different angle. I will be discussing this with the service department when I go in for the first service.
Uriyo_
Sep 8, 2021 08:46 AM
