Shifting hard and notchy when cold?
Old Nov 30, 2004 | 08:37 PM
Slip and Slide's Avatar
Slip and Slide
Default Shifting hard and notchy when cold?
I only noticed it since it started to get cold here. But it almost feels as if it doesn't want to go into gear unless forced. You think the synchros are going bad or is this a common thing for the stock trans. fluid. Maybe I should try changing it with some Mobil 1?
Old Dec 1, 2004 | 02:58 AM
ttsupra94's Avatar
ttsupra94
If it's really cold outside, i give the car a couple minutes to warm up. Then the shifting feels fine
Old Dec 1, 2004 | 04:03 AM
DavesZ#3's Avatar
DavesZ#3
Every standard that I've owned has done that. The thick trans grease gets even thicker when the temperature drops in addition to the fact that metalic parts fit tighter when cold.
I start my car, put it in neutral and let it idle for a while doing my "pre-flight" and that seems to help some. Of course, in LA it's not quite as cold as PA so I'm probably not getting it as bad a you.
Old Dec 1, 2004 | 05:06 AM
King Tut's Avatar
King Tut
Normal.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
