Would Coilovers fix Tire Feather?
I've heard that it does fix the problem, and it makes sense that if the suspension alignment is the problem then replacing it should do the trick.
if not aftermarket coilovers, then NISMO S_tune?
Being the alignment is so sensitive on the 350z, It would seem to me (correct me if im wrong) but you would need a alignment everytime you adjust your coilovers?
I have the Nismo S-Tune and so far no problems
I had Eibach with stock damper for 4 months, and I also had Tein Flex Coilover 6 months. It doesn't fix anything about the feathering......I don't know about the Nismo though. I think best way to get over this problem is to get the camber kits, and I'm planning to try that next year....it's so sensitive...that's all I can say.......for now...IMO
