Curb Weight
Old Nov 4, 2002 | 01:42 PM
fdao's Avatar
fdao
Default Curb Weight
Has anyone ever check their Z's weight on their registration paper? I recently checked mine and it's 3330 lbs! A far cry from the 3225 lbs for the Track model! I was always under the assumption that the curb weight quoted from the factory should be the correct weight at the time of registration.
Any thoughts?
Old Nov 4, 2002 | 01:45 PM
ares's Avatar
ares
Veteran
I think there must be a reason for that. I dont know what it is. hard to believe its off by 105lbs...
I wanna get my Z on a tractor trailer weight scale, theres one up to the north between me and tenn, might give it a shot soon, the drive up there in a Z would be good fun as well.
Old Nov 4, 2002 | 01:47 PM
fdao's Avatar
fdao
Sounds good. Let me know what you find if you decide to do it .
Maybe the weight of the vehicle included a 105 lb person in the car
Old Nov 4, 2002 | 01:53 PM
ares's Avatar
ares
Veteran
yeah could take a while, Im very busy for now till about xmas, but hopefully I can take a trip through the mountains then.
Old Nov 4, 2002 | 02:01 PM
jfive's Avatar
jfive
maybe gas and fluids
Old Nov 4, 2002 | 02:15 PM
steve c's Avatar
steve c
Interesting. My ITR weighed 2558 pounds with no driver a 1/4 tank of gas and all the stuff still in it -- about 120 pounds UNDER what Honda says -- likewise my 99 M coupe which is supposed to tip the scales at 3131 is 2967 with the same conditions. (both of these weights were taken on a 3 grand corner balance setup and are accurate).
The listed weights it seems are generally not accurate, let's hope some of the Z's turn out to be a bit lighter than Nissan claims.
Old Nov 4, 2002 | 10:14 PM
fdao's Avatar
fdao
hmmm, intersting. The reported curb weight from the factory usually include all the fluids and full tank of gas. So, where the heck did this 100+ lbs come from !
Old Nov 5, 2002 | 04:44 AM
j's350z's Avatar
j's350z
I weighed my base Z at the track with no spare and a 1/4 tank of gas. It weighed in at 3165 without me. With a full tank of gas it should weigh around 3300lbs.....Just my input.
Jason
NJ
Old Nov 5, 2002 | 06:24 AM
John's Avatar
John
Corner weighted my Track model with no spare, jack, and a 1/4 tank of gas this weekend at Summit Point:
872 865
704 696
Total: 3137
With me in it: 3286
Old Nov 5, 2002 | 07:14 AM
Flyingscot's Avatar
Flyingscot
872 865
704 696
Total: 3137
This is almost too good to be true for a production car. The diagonal weights are 1lb off a perfect 50:50. You must have been very surprised. I'm shocked you didn't comment on this because this is probably the most fantastic news yet.
Old Nov 5, 2002 | 07:22 AM
ares's Avatar
ares
Veteran
suddenly the base isnt the lightest? perhaps a quarter tank of gas is variable. but none the less, this is intriguing news indeed.
Old Nov 5, 2002 | 07:27 AM
WashUJon's Avatar
WashUJon
Maybe the scale wasn't calibrated.
Old Nov 5, 2002 | 07:30 AM
John's Avatar
John
This was no cheap scale... Many thanks to Alex Ratcliffe for letting me use it. And yes, it was calibrated and tared.
Old Nov 5, 2002 | 07:31 AM
ares's Avatar
ares
Veteran
well do you weigh 149 lbs?
WayneTN's Avatar
WayneTN
Default good balance.....
Then.........the driver gets in..........
I bet it's still pretty close, though........
WayneTN
Old Nov 5, 2002 | 07:37 AM
John's Avatar
John
Yes, I am a skimpy 149lbs (and over 6' too)... all that beer seems to have no effect on my belly (or lack thereof).
Old Nov 5, 2002 | 07:45 AM
Flyingscot's Avatar
Flyingscot
Default Re: good balance.....
WayneTN
oops, I didn't spot that. I'm so use to corner wgt balancing with me in the car. I though it was too good to be true.
If Hedonist can't do it again with him in the car then I will do it in January when I get my track model (minus the Nav). I weight 190lbs with clothes on I'm interested to see how close the factory got it.
Old Nov 5, 2002 | 07:47 AM
Michael-Dallas's Avatar
Michael-Dallas
FWIW, ChinaClipper weighed the spare tire in his Track and it was a whopping 41lbs! Also, Nissan lists the Shipping Weight as 3099lbs in the Certificate of Origin. This is what the DMV used when I registered/titled mine.
Michael.
Also, gas weighs roughly 7lbs/gal.
Old Nov 5, 2002 | 07:49 AM
John's Avatar
John
I have the corner weights of me in the car in my desk at home... I'll dig them up later and post them...
Old Nov 5, 2002 | 07:56 AM
Flyingscot's Avatar
Flyingscot
Good stuff old fellow!
BTW: I'm going to be at the THSCC VIR Full course event in February with my Z if you want to join me. I don't think they have posted the event yet so watch this space.
Is there a good way to reduce the understeer of the stock setup on a track like VIR?
